Hi guys, I am very new to the world of old clocks and really am just starting to learn!
I recently bought a longcase clock from some near me and now I have it setup, it is clear I have some work to do.
The main issues seem to be, the time side weight once attached drags the movement around quickly. Hopefully the video illustrates the problem.
As this is the first weight driven clock I’ve had, I’m wondering if turning the hands should be as difficult as it appears to be? Does this sound normal?
There are a few other things....I think the gut may need replaced.The strike is off...striking 6 at 1 (I moved the hour hand so hopefully that is the correct method to rectify that?! Additionally, the hour hand seems very loose (push pull movement front to back as you look at the face).
Any help or pointers are greatly appreciated as I’m on a very sharp learning curve!!
Cheers,
Graeme
Cheers,
Graeme
