New Haven Wilson 30 day banjo question.
Gerald Zwick
New Member
Sep 3, 2010
I just bought a New Haven Wilson at the Schmitt Auction this weekend. I have already cleaned and reassembled the 30 day movement and my question is about the two wheels above the center wheel. They sit one atop the other are spoked with each wheel having a small hole in one of its spokes. There is a curled spring which looks like it should be attached or connected to both wheels. Currently the clock hands are lacking any tension at all. I'm sure the springs serve a function and would appreciate help to find out the correct way to use the spring.
Thanks for your help.
Dick Feldman
Sep 1, 2000
2,459
174
Colorado, usa
Gerald,
I am afraid you have not given enough information. How about a few pictures?
Unless someone has one of those movements handy and/or apart, your questions cannot easily be answered.
Best Regards,
Dick Feldman
R. Croswell
10,914
1,076
www.greenfieldclockshop.com
This picture is a 30-day New Haven from a similar clock. The spring takes up the slop or backlash in the gears so the minute hand has no "looseness" and points exactly to the time. The spring needs to be in place.
eskmill
Aug 24, 2000
7,135
36
The device Croswell identified for you is a mechanical gear-set known as "Scissors Gears."
Scissors gears have been used in many mechanical assemblies for eons. The advantage is obvious but they do add a little friction and are not well understood.
46,112
1,757
They have to have a little tension or the two wheels will not work in tandem. Set it with about one tooth worth of tension. You find this arrangement often on dual wind time only clocks.
164,723
1,433,102
85,765
silverstreak
2,863
