I have a movement on the bench that I haven't seen before. I'd like to know the maker and approximate age. The only mark I can find is a C on the suspension spring support. I also need to repair or replace the suspension spring, as one leg is broken. I can't figure out how to remove the spring from the horizontal shaft that supports the pendulum. I've looked around for replacement suspension spring assembly but have not found one.
The movement has some nice features - deadbeat escapement, double chain and elaborate crutch. I believe these are all features of an accurate clock... any help would be much appreciated!
