New Haven Saturn regulator
Discussion in 'General Clock Discussions' started by Melvin Chase, Sep 12, 2017.
  1. Melvin Chase
    Melvin Chase Registered User
    Feb 26, 2014
    7
    Does anyone know if someone has produced cases or movements for the "Saturn" regulators produced by New Haven Co. ?
    Helping a friend with an old clock. It has a very clean movement that looks too new to be an original. The case is also very clean and appears to be new, yet has a pendulum and label which appear to be original. This is a spring-powered version, not weight driven.
    (Pictures are not immediately available)
    ANY HELP IS APPRECIATED.
  2. Steven Thornberry
    Jan 15, 2004
    17,972
    22
    Pictures would surely help. I am personally unaware of anyone who manufactured "repro" cases of the Saturn (that's what I think you mean -- correct me if wrong). A movement can be cleaned to look brand new. Is it a New Haven movement? Cases can be refinished to restore a like-new look. If the label looks original, that goes a long way toward suspecting the whole clock could be original (save for any refinishing). As I said, pictures will help, both of the case, the label, and the movement.
  3. Melvin Chase
    Feb 26, 2014
    7
    Here are some photos of the Saturn - I learned that this clock had been stored for many years and probably rarely used until re-conditioned sometime during the 1970's. The clock case is probably original, however, I'd like to confirm that the movement is correct. Is the plate at the inside of the case typical of this model? The dial is rough and does not show the "star" logo [Yes - I know that base of the case is not visible - it is being re-glued]
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Any help is appreciated.
  4. Steven Thornberry
    Jan 15, 2004
    17,972
    22
    Your clock is unusual in having an eight-day time-only movement. A thirty-day time-only or an eight-day weight time-only movement are more common. I would not be surprised that the wooden dial mount inside the case was necessary to place the movement closer to the dial. If there are no obvious signs that the movement is not original to the case or that the mounting board was added post-production, I would accept the clock as original.
Similar Threads - Haven Saturn regulator Forum Date
New Haven Banjo "Winsome" General Clock Discussions Friday at 12:58 PM
New Haven ID? General Clock Discussions Oct 8, 2017
New Haven Saturn Minute Hand-Counter-Balance?? General Clock Discussions Aug 1, 2010
New Haven Saturn-Need To Know What Weight Is Needed-Can't Keep It Running! General Clock Discussions Dec 7, 2008
