New Haven restoration-Count wheel/count lever
clc
May 30, 2017
346
Hi all.
I finally put together my first movement! After cleaning all the wheels plates, mainsprings, etc. I put it together.
The photo here shows how the count lever is slightly bent/warped and the way it fits into the count wheel.
Because of its shape it rubs the top-back side of the teeth as the wheel turns and won't go down all the way therefore it continues striking until manually the count lever is guided into stop.
What do you suggest could be done?
Thanks,
13,780
1,423
Bend the rod part at the top, where it makes the right angle downward bend, ever so slightly away from the movement. Then straighten the thin blade part so you will have a clean drop in the deep slots.
clc
May 30, 2017
346
Thanks, Willie X.
I first thought of adjusting the blade. I'm glad I did what you suggested. Now I have "a clean drop in the deep slots".
Thanks,
Carlos
clc
May 30, 2017
346
Thanks for your help Willie X.
I lubricated all the pivots, removed the retaining rings from the mainspring and the clock has been running now for about 5 hours now.
Carlos
clc
May 30, 2017
346
Happy inform that 5 days later the clock still running.
Thanks,
Carlos
165,445
1,440,183
86,232
Vicepa
2,873
