New Haven Novelty
Discussion in 'Clock Repair' started by wbranko, Apr 24, 2017.
  1. wbranko
    wbranko Registered User
    Feb 1, 2004
    388
    I am working on a New Haven novelty clock with a fairly large movement. I have not seen a set up like this before. I got to the movement, and can not figure out how to remove the bezel and glass...is it press fit, screw fit:???:? Anyone who has worked on one of these before, please help me out. How do I get to the hands? 302934.jpg 302935.jpg 302936.jpg
  2. shutterbug
    40,799
    732
    Look for a thin wire around the circumference of the dial. It will have a small gap where you can insert a small screwdriver or something to remove it. It's spring loaded. There were several unique ways to hold things together. I doubt that it's press fit, although the glass might be. The bezel should come off some way. :)
  3. wbranko
    Feb 1, 2004
    388
    Shutterbug,
    Thanks!! You sent me on the right track. I started REALLY looking at the gap. I could not see a spring or spot to insert a blade...so I used a razor blade to pry on the bezel. To my surprise, it gave a little. Working carefully around the bezel, it eventually popped off. So it was a press fit after all! Who knew:???:?
    All's well that ends well. Now on to the cleaning!
  4. shutterbug
    40,799
    732
