New Haven Mainspring advice
Discussion in 'Clock Repair' started by Hogshair, Apr 20, 2017.
  1. Hogshair
    Hogshair Registered User
    Sep 6, 2014
    41
    Hi all, the spring in the picture is from the strike side of my New Haven movement. Is it still serviceable, or should it be replaced? I dismantled the clock so as to reset the strike (thanks RC & TD) and have another chance to practice resembling.
    As this is an open spring I assume the rules (just read about some of those) for a spring that lives in a barrel don't apply? So, apart from obvious things like cracks and rust, how do I tell if it's a bin job due to lack of power?
    Cheers
    Hogs.
    [​IMG]
    The more I ask the more I learn.
  2. Willie X
    Willie X Registered User
    8,065
    29
    Looks normal to me.
  3. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    I am not sure if it is a bin job - but if it is - I have found it helpful to keep these old springs to use when I need to make certain kinds of springs or spring washers. So if you decided that it is a bin job - make it an "old spring metal" bin job for when you need a nice piece of spring steel in the future - and don't just toss it away for good.
  4. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    620
    Science teacher, writer
    Lancaster, Ohio, USA
    Looks okay. You'll likely have to tighten the innermost coil so that the hook on the winding arbor can reach through the hole on the mainspring.
    M Kinsler
  5. R. Croswell
    R. Croswell Registered User
    6,642
    23
    Looks like it should be OK. Any spring that's been in service for a few years will expand less than a brand new spring but will still have plenty of power.
    RCc
  6. shutterbug
    34,331
    I almost never replace a spring, because most of the new ones are junk.
  7. Kevin W.
    Kevin W. Registered User
    20,163
    10
    I am with Shutt, rarely replace main springs. The one in the picture looks fine to re use.
  8. Hogshair
    Sep 6, 2014
    41
    Hi all, thanks for the help, appreciate it. Surprised to hear that new springs don't make the grade.:(
    Is that across the board as in all suppliers or are there one or two manufactures out there still turning out the good stuff?
    Cheers
    Hogs.
  9. shutterbug
    34,331
    German springs are good. Japan makes fair springs. Indian springs are not good. Many suppliers will no longer tell you where they get their springs.
Similar Threads - Haven Mainspring advice Forum Date
New Haven crystal regulator mainspring servicing Clock Repair Mar 30, 2016
New Haven car clock mainspring Clock Repair Feb 6, 2015
New Haven Kitchen Clock- Odd Mainspring Post Clock Repair Dec 17, 2014
New Haven Cabinet Clock Mainspring Help Clock Repair Mar 25, 2014
New Haven Tambour Mainspring Size ?? Clock Repair Apr 4, 2009
