New Haven Hammer Head. Wood?
wow
Jun 24, 2008
5,579
663
76
Pineville, La. (central La.)
Just finished this one. Got the chimes and strike all synced, put it in the case and it sounded terrible. Chimes and strike went “clunk” instead of chiming. Adjusted hammer tails and everything else I could find to adjust and they still clunked. Finally noticed the hammer heads were wood and loose in the hammers. All of them. I thought they were originally leather. Should I glue the wood back in or replace with leather. Think somebody replaced them with wood:???:?
EB93711B-D342-4821-B4C0-AE2F9B56FF6C.jpeg 3AD6764C-B555-49FD-8DBF-81234911E908.jpeg
ChimeTime
May 4, 2021
224
80
71
NE Georgia
Those weren't "hammers", they were "mallets". :)
Actually, I'm wondering if the deadening came from the loose wood slipping down onto the chime rods. IOW, if they were secure in the hammers, would you have had the same dead note ?
wow
Jun 24, 2008
5,579
663
76
I think the looseness is definitely causing the thud. Just wondering about the wood. Never seen wood hammer heads on chimes.
ChimeTime
May 4, 2021
224
80
71
NE Georgia
And that is the root motivation here. I'm looking for softer chime striking materials because She Who Must Be Obeyed is easily annoyed, and wood at one time was a prime candidate.
14,998
1,865
In that case, it might be best to make the jump all the way to felt! Willie X
wow
Jun 24, 2008
5,579
663
76
In that case, it might be best to make the jump all the way to felt. Willie X
I’ve done a few of these tambors before and I don’t think they had wood hammer heads. They all had nice quiet chimes. So felt would be better than leather? Have you ever seen them with wood, Willie?
Isaac
Aug 5, 2013
1,181
296
Yeah, my "Melrose" when I had it used soft leather hammers and had an audible but quiet chime.
14,998
1,865
Yes, leather is what they had.
I mentioned 'felt' to appease "She Who Must Be Obeyed". :)
Reactions: Royce
Bruce Alexander
NAWCC Brass Member
Feb 22, 2010
7,627
880
Hanover, PA
www.testoftimeclocks.com
I've seen wood inserts but so far they have all been in Sonora Bell Chimes. I've used Delrin inserts on said clocks when the original leather has badly deteriorated. If the chime rods are well tuned and resonant, I see no reason why they wood wouldn't work just fine.
Maybe the previous owner was hard of hearing or something. :)
At any rate soft leather works well and can be conditioned into a harder material if needed.
Is that one of those infamous 3-plate movements Will? If so, I'm sure you'll be glad to have this one done, eh?
Bruce
wow
Jun 24, 2008
5,579
663
76
Bruce
It’s the two plate, Bruce, but they are quite complicated. They are covered in Conover’s chime book. I’ve worked on several of these lately and have finally reached the place where I don’t have to read the book to set the chimes. I read it so many times on the first one, I almost memorized that section. This one, the Junghans, and the Seth Thomas 124 are all buggers.Conover’s book sure helps. He doesn’t cover wooden hammer heads, though.
47,564
2,215
I think a wooden dowel of the right size might look tempting to a shade tree mechanic. Pretty sure the originals were leather.
R. Croswell
11,139
1,204
www.greenfieldclockshop.com
I agree that wood was not original but I had a simple time & strike New Haven with a wood hammer tip that sounded just fine. Perhaps a little too bright for some. I don't see any reason that the wood hammer tips here shouldn't work OK as long as they are tight and come to rest about 1/8" above the tone rods. "Clunking" sound is usually caused when the hammers are too close to the tone rods, and/or when something is loose. I would probably replace these with leather just to be original. Wood or leather it should sound fine is everything else is right.
Reactions: Willie X
wow
Jun 24, 2008
5,579
663
76
Thanks, RC. I came to the same conclusion. I used leather inserts and they all sound much better. They are nice and quiet. I like them quiet. Hope the owner does too. Only problem is, when I put it back together the hour strike was 12 every time. Oh, well, got to pull it out again and see what is happening to the rack. :???:
wow
Jun 24, 2008
5,579
663
76
That is risky. Good luck. Has the clock ever worked for the owner or owners?
Hope you saved the wood just in case.
It’s never worked for them. She’s never found anybody who could fix it. The last repairer lost three levers off of it and RC had them. She was so excited to hear I got the lost parts. I have been so busy I have not finished it till now. I did save the wood pieces but I think she’ll love the sound. All of these I have worked on sounded nice and quiet.
168,853
1,473,375
48,613
johndavidcham
2,955
