New Haven Gingerbread Clock movement mounted in wood blocks?
Discussion in 'Clock Case Restoration and Repair' started by saskjoe, Feb 18, 2012.
  1. saskjoe
    saskjoe Registered User
    Dec 1, 2011
    282
    I'm trying to rebuild this clock that I bought missing its movement and hands. Once I read a reference to the movement being held in wood blocks. What I would like is a picture of an original set of these mounting blocks. I think that is what belongs in there as there are no impressions left by metal mounting lugs and the hole spacing is a bit off as well for that type of bracket. The rear label calls it a 1 day New Haven Tigris. As seen in photos, some wood trim will have to be fabricated. What are the likely type of wood used on this? Thanks for now, Joe. clock 159.jpg clock 158.jpg
  2. Jim Hartog
    Jim Hartog Registered User
    Jan 6, 2010
    371
    house husband
    Hello Joe.
    I have one of these that I restored (new base, dial paper, pendulum, glass). The Tigris is on page 332 of Tran's New Haven book as clock number 1350. It came as a 1 day strike or a one day strike and alarm and appeared in a catalogue in 1886. The book has the wood as black walnut, which is what I used. I will take some photos of the clock, movement and mounting blocks and post them shortly.
    Jim
  3. Jim Hartog
    Jan 6, 2010
    371
    house husband
    Hello again Joe,
    I'm struggling with the new photo attachment thing. I hope they appear. If not, I will try again.
    Bottom block (walnut)
    3/4" x 3/4" x 3 1/8"
    1/4" x 3/8" cutouts for the pillars
    lateral groove for the plates is about 3/64" and runs 1/3 from the front and 2/3 from the back
    Top block (poplar)
    3/4" x 1 1/4" x 3 3/8"
    1/4" x 7/16" cutouts for the pillars (top pillars are further apart than bottom pillars)
    lateral groove for the plates same as the bottom
    1 1/4" groove for clearance for the fly
    3/16" groove for clearance for the end of the fly arbor
    Jim
  4. saskjoe
    Dec 1, 2011
    282
    Thank you so much for these photos and info! When I saw the top block picture it looked familiar and sure enough I had that piece in my box of spares. The search did not turn up the bottom block but that's fine. I wonder if the mounting screws should be put in from the back instead due to what is now rather fragile wood. On the other hand I don't want to be horologically incorrect and surely some sort of mounting point strengthening will be possible. Nice clock by the way. Very similar to mine save for the base and glass details and the alarm. In other threads people mention disabling the alarm but this one can be stopped by rotating the bell to the right spot. Thanks again, Joe.
  5. harold bain
    Donor NAWCC Member
    39,946
    Joe, if you don't wind the alarm, it won't bother you. No need to rotate the bell.
  6. saskjoe
    Dec 1, 2011
    282
    That is true but a good design detail discovery is always fun.
  7. Jim Hartog
    Jan 6, 2010
    371
    house husband
    Hello Joe,
    When I was disassembling and re-assembling for the photos I noticed that the top block is up quite far to the point that the screwdriver is quite angled to get in there. It may be a good idea to install the top block on the back with the back removed. Good luck finding a movement.
    Jim
Similar Threads - Haven Gingerbread Clock Forum Date
New Haven Cunard Striking Clock Question Clock Case Restoration and Repair Aug 8, 2017
Seeking Suggestions On Preserving Remaining Picture on New Haven Banjo Clock Case Restoration and Repair Jul 21, 2017
New Haven Grecian Clock Case Restoration and Repair Nov 18, 2014
What would you do? Snapped Chime Rod on Miniature New Haven Banjo Clock Clock Case Restoration and Repair Jun 28, 2014
Need Side Columns for Gingerbread Clock Clock Case Restoration and Repair Oct 7, 2012
