demoman3955
- Apr 9, 2022
- 626
- 223
- 43
- 66
- Country
So I have this clock that wouldn’t run and most in part to the suspension spring rod assembly being too low and hitting the winding arbor .. The suspension spring was barely on it to begin with. I put the spring closer to where it should be and it started running just fine. Problem is, that it runs too fast, and with the bob as far down as it can go, is gaining 5 plus minutes a day. If I put a longer suspension spring on it, the bob will be too low in the case. My only thought is that it’s a movement from another clock that used a longer bob that fit in the case. I’ll see if the links to YouTube work.
