New Haven Clock
Dewi Clwyd
Jul 20, 2018
10
74
As a hobbyist I was interested to find out more about a wall clock I have recently been asked to repair. The owner suspected a broken spring. I agreed to look at it without having seen it.
I include pics of the clock and movement to see if you venerable people can date (approximately) the clock. I have seen online pics of movements that have nuts holding the plates together and wonder when nuts superseded pins, as this might help. It is a 9¼ movement giving an hourly chime. Happily I can report that the clock is running again, it just needed a general service.
I had never seen or worked on a New Haven before so the disassembly and subsequent reassembly proved to be an unforgettable experience, especially the springs!
What can you tell me?
steamer471
Nov 2, 2013
615
127
56
Charlotte NC
Anglo clock. I have several and from what I have learned they are usually American movements cased in English made cabinets. My best guess is somewhere around 1880. Search the term and you'll find many examples. I recently purchased three. All marked New Haven, I believe these were a direct result of Chauncy Jerome's dealings in Europe importing clocks there.
14,083
1,508
Usually the US supplied product was a kit, including the dial, pendulum and hands.
From what I've seen, New Haven may have been the top player in this market.
In today's terms, this would have been called 'dumping', or a 'trade war'. It's still going on today but the players and products have changed.
My 2, Willie X
Dewi Clwyd
Jul 20, 2018
10
74
Interesting information steamer.
The owner has finally brought me the brass rim complete with broken glass and hinge. Question...... how do I fit a new glass into the rim:???:?? Pics included.
steamer471
Nov 2, 2013
615
127
56
Charlotte NC
I have been fortunate enough not to have to take on this project yet. I have an English clock that has a metal ring on the inside of the bezel that holds the glass. I suspect that is what is holding mine as well. Here's a pic if it will help. Someone with more experience maybe can help. 20210613_075818.jpg 20210613_075810 (1).jpg
steamer471
Nov 2, 2013
615
127
56
Charlotte NC
To clarify this is a picture of one of my Anglo's. The one I have with a inner ring is a latter clock. I have read where some glasses are cut close and the bezel is actually heated and then allowed to cool around the glass.
14,083
1,508
This one would have some type of retainers. Usually soldered in rectangular brass clips, short lengths of wire, or a long circular brass wire that went all the way around, soldered at intervals. I've seen some that used glaziers putty.
There should be plenty of 'evidence left at the scene', to give you some direction ...
Dewi Clwyd
Jul 20, 2018
10
74
Thanks for your reply... and Yes! you are correct. It's a very close fit but there is an inner ring. After looking at it from all angles I decided to give it a go. Took some pulling whilst trying not to distort the rim but I could see the gap slowly widening until the rings finally seperated. Just got to wait for a new glass to be cut. Original glass thickness was 1/16th, if I can't get 2mm (nearest equivalent) I'll have to squeeze 3mm in.
Reactions: steamer471
14,083
1,508
Probably better to spend a little time and find the glass in the right thickness. For at least two reasons: it will fit without mods and be noticeably lighter. Willie X
166,231
1,448,297
86,745
Timemaestro
2,906
