New Haven 1870s tapered pins for movement plates
legosnell
Nov 5, 2020
246
68
I need to buy some papered pins for a New Haven 1870s movement plates. I'm not sure what size to order from timesavers. Maybe just an assortment? Any idea what will work or what size I should order. I'm not able to measure the one or two that I didn't manage to lose since I'm away from home for a week or so. Here is a picture of the movement before I managed to lose the tapered pins. Appreciate any help. Larry Gosnell
14,781
1,744
Get the 1" long steel ones. Usually the 'medium' size but I can get you the exact measurements later.
The assortments are usually nothing but a disappointment.
If you don't need anything else to make up a parts order, a length of close fitting soft iron wire, bent on both ends is a good (maybe better) substitute. The "S" wires will never fall out.
Reactions: legosnell
legosnell
Nov 5, 2020
246
68
That would be great Willie, sure appreciate it. I'm trying to put together a Timesavers order while I'm out of town and wanted to include the tapered pins.
14,781
1,744
To be safe, I would order both the medium (.030" x .065") and the large (.040" x .075"). All steel and all 1" long, Merritt's numbers are P-858 and P-859, respectfully.
Might as well add the small (.015" x .053"), also 1" long, and you will have all the bases covered ... The small will mostly be used in European clocks though.
legosnell
Nov 5, 2020
246
68
Ok, perfect exactly what I needed to know. Thank you very much Willie.
Swanicyouth
Nov 10, 2019
173
I just used the ones from Merrits. I dunno the size, but they are brass & maybe 3/4” long. The taper goes from big to small pretty noticeably.
I bought them for holding hands on the movement, but they also worked fine replacing the toothpicks that were holding my Ingraham movement together.
legosnell
Nov 5, 2020
246
68
I'm hearing Merrits mentioned here several times instead of timesavers.
R. Croswell
11,112
1,186
www.greenfieldclockshop.com
I would recommend brass tapered pins in steel posts, and steel tapered pins in brass posts. The first time ordering I would get the assortment, afterwards just order the size(s) you run low on. www.merritts.com should also have these. They give good service and are located in PA but their website is dreadfully slow and a pain to navigate......in my opinion.
47,379
2,133
It would be nice if they just made one size, and made them long enough that you could just cut off the parts you don't want. The cut off parts could likely be used sometime too.
168,218
1,467,035
48,171
garyray
2,955
