First ever post here - hope it is OK that it is a question not an 'about me' ....
I typically play in the watch arena but I'm venturing into clocks too - I acquired this from somebody local to me for a can't refuse price, it does run but I plan to service it before it runs in anger.
I believe it to be a JUF Jahresuhrenfabrik pre 1920 or so but I'm guessing and basing this on similar clocks that I've seen. The dome is glass not plastic, the serial number is 86092. The 'pendulum' is measuring at 120mm by 0.08 by 0.66 (the latter is the width and tricky to measure), I have no clue if this is correct but it does not hang how I'd expect - aka not vertical when the clock is horizontal, don't know if this is correct or not - these clocks are new to me. The bottom pendulum block doesn't look right, looks a bit 'diy' - need a pic of a good one or a source of same - or even good parts for one of these, the top pendulum support seems to have suffered some in its day too. There's no slop in the gear train, no rebushing required so all in all it ain't too bad, tempted to just lube it but the OCD is kicking in as it does with any 'unknown' mech on my bench.
Anyhow enough of that - what is it, how old is it, what did a buy - pig or poke - (I like it whichever ...)
