New clock - id help needed
Discussion in '400-Day & Atmos' started by spresto9, May 15, 2017.
  1. spresto9
    spresto9 Registered User
    Oct 22, 2012
    22
    #1 spresto9, May 15, 2017
    Hi all,
    I Just won this clock on Ebay and after an hour of searching the web have failed to identify it.
    Could anyone please help with any info as its missing the suspension and I would like to order parts before the clock arrives in the post, also is there something missing from the suspension bracket?
    This will be my third 400 day clock, the last two where given away as gifts but this one I think I will Keep!
    I would greatly appreciate any help you can give, many thanks,
    Steve Preston
  2. John Hubby
    Sep 7, 2000
    11,208
    19
    The Woodlands, TX
    Steve, thanks for posting your inquiry and the photos of your clock. You have a Kienzle Plate 1601, however I was not able to decipher the serial number to be able to date it accurately. If you could post a clear photo of the number or just post it here that will help a lot. The pendulum is also a Kienzle but doesn't have a matching serial number so it isn't original to the clock even though it is the correct pendulum.
    Your suspension is missing the "C" gimbal that clamps to the suspension spring, that will need to be replaced before your clock can work. You may be able to obtain a replacement from Horolovar or one of our members may be able to help.
    I'll post more after you provide confirmation of the serial number.
  3. spresto9
    Oct 22, 2012
    22
    Thanks John thats very helpful Ill post more the serial No. when I recive the clock.
    Cherrs Steve
  4. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    1,690
    Aerospace Engineer
    San Antonio, TX
    I was missing the C gimbal on a JUF clock. I was able to buy one from an ebay seller in Australia. He makes batches of these and they are excellent replacements and he was very easy to work with. Search ebay for "jahresuhr suspension block".
    Kurt
  5. spresto9
    Oct 22, 2012
    22
    Thanks its on order! any idea what fork and bottom block would be sutible?
    Cheers Steve
  6. spresto9
    Oct 22, 2012
    22
    Hi all,
    I now have the clock in my possession and the serial no. is 136400 so any more info would be greatly appreciated.
    Someone has been at this one!
    Having striped the clock I find that the eccentric is very loose in the plate, the escape wheel is very badly damaged with several teeth twisted and bent also one pallet is badly chipped and the rod bent in three places, how, its only short!!
    So far I have dressed the chip out of the pallet and adjusted it back to the original position. The escape wheel is too far gone to repair, I have a spare JUF movement and the escape seems identical, just need shift the escapement on its arbour to line up.
    I can adjust the eccentric to get what looks like a good lock when moved by hand, but as mentioned it is very easy to turn, any thoughts on how to stiffen up the adjustment? I don't want to lock it as I'm sure I will have to adjust it again after the clock is cleaned and polished.
    Can anyone suggest the correct length for the fork as I would like to order one ASAP.
    Cheers, Steve.
Similar Threads - clock help needed Forum Date
Keininger Obegfell clock identification help needed 400-Day & Atmos Feb 15, 2017
Help needed to get Mums old clock working 400-Day & Atmos May 13, 2016
Help needed with New Master 100 days clock 400-Day & Atmos Feb 2, 2014
Help needed identifying hands for this clock 400-Day & Atmos Apr 9, 2012
Please Help! 400 day Phillip Haas clock dial needed 400-Day & Atmos Nov 26, 2010
