Help New Ansonia regulator suspension spring....
Discussion in 'Clock Repair' started by Clockinit, Mar 16, 2020.
  1. Clockinit
    Clockinit Registered User
    Nov 4, 2019
    187
    According to one of Bangter's methods of removing the trundles, is to drill the holes in the top shroud...Where do I find drill bits that small...these Trundles are very, very thin...!!
    Bob
  2. shutterbug
    41,701
    904
    It's a very slight widening and tapering of the outermost surface of bushings. It just prevents the arbor from interfering with the pivot's fit in the bushing. It can apply to any operation that smooths the surface of a hole.
  3. Clockinit
    Nov 4, 2019
    187
    That's what I thought...would that be the same as securing the trundles in the upper shroud of a lantern pinion after having drilled the tops to remove the trundles and replace them...??
    2nd question.....Where do I find drill bits that small...these trundles are very, very thin...!!
    Bob
  4. Clockinit
    Nov 4, 2019
    187
    I think I answered my 2nd question...That would be staking...
  5. shutterbug
    41,701
    904
    You can usually push them out with a little pressure. Personally, I like removing the trundle cap and replacing them that way, but I'm in the minority around here :D
  6. Clockinit
    Nov 4, 2019
    187
    Yeah there are no holes at the top of the shroud...I'd have to drill a completely new hole...I think I'm gonna give removing the top shroud a try....
  7. shutterbug
    41,701
    904
    A crows foot works great for that. Brace the cap on it and tap the arbor downward with a hollow punch to protect the pivot. Be sure to keep the punch straight up and down ;) Getting it back on requires patience. You have to wiggle the trundles into place like putting wheels in a movement :)
  8. Clockinit
    Nov 4, 2019
    187
    Thanks 'Bugsey...I gotta scrounge up a hollow punch...Hey, can you check out my post on how to on an ASONIA arbor:???: Separating the arbor from the cap.....
    Bobo_O
  9. shutterbug
    41,701
    904
