New addition: Harder
Discussion in '400-Day & Atmos' started by etmb61, Oct 10, 2016.
  1. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,581
    193
    Retired Avionics Technician
    Mascoutah, IL
    I've had this on my wish list for a while, and finally found one at a reasonable price. It has number 1733R, it's complete, and is in fairly good shape.
    Eric
      File size:
      148.9 KB
      141
  2. pollythecat
    pollythecat Registered User
    Jul 17, 2016
    86
    East Sussex
    That thing is nice and well worth the persistence, wish I could find one too :)
  3. John Hubby
    John Hubby Senior Administrator Emeritus
    Sep 7, 2000
    12,286
    224
    The Woodlands, TX
    Congratulations, Eric! Very nice early example of the full 3-Patent dial, appears complete and original possibly including the velour cover of the base. Based on the serial number this one was made in Feb.-Mar. 1884.
    Questions: Is the pendulum disc solid turned brass? Also, is there a serial number scribed or written underneath the disc? Any other marks such as service dates, etc.?
    Will look forward to seeing it after you do your restoration magic.
  4. etmb61
    Oct 25, 2010
    2,581
    193
    Mascoutah, IL
    Hi John,
    Yes the disc is solid brass, but it's a more recent replacement. It measures 75mm x 10.7mm, and is 2mm thick. It has what look like the original adjustment weights and screw, and the center post and screw. No markings. The installed suspension spring which makes it slightly fast is about 0.0025".
    Should the proper disc be about the same dimensions as pendulum 21?
    It does look like it has the original velour on the base, violet to blue-violet.
    The "match" number visible on the plates and pediment is "6". The only other added marking visible without taking it apart is "93965" scribed onto the bottom of the base.
    At some point the pediment was broken off, so the repair was to extract what could be of the broken screws and solder brass pins in the pediment to hold it on.
    I'll post some better pictures for the record a little later.
    Eric
  5. etmb61
    Oct 25, 2010
    2,581
    193
    Mascoutah, IL
    Here it is:
      File size:
      103.1 KB
      87
      File size:
      127.3 KB
      97
      File size:
      107 KB
      82
      File size:
      116.3 KB
      73
      File size:
      92.3 KB
      88
      File size:
      93.5 KB
      74
      File size:
      113.1 KB
      81
      File size:
      95.2 KB
      75
      File size:
      100.8 KB
      72
  6. daveR
    daveR Registered User
    Sep 10, 2008
    311
    7
    hospital storeman
    melbourne, Australia
    A nice one indeed. Fine hands and dial figures. Will you try and replace the velour, though the colour might be a challenge. a bit of home dyeing perhaps! Will you take it to a brilliant polish or leave it as it is, particularly the base?
    David
  7. etmb61
    Oct 25, 2010
    2,581
    193
    Mascoutah, IL
    I'm very happy with it.
    For now it will retain its "patina". There's no visible corrosion and the color is fairly uniform. If I make anything too shiny while working on it I'll polish it all up.
    I want to reverse the repair on the pediment and find/have made a proper disc for the pendulum.
    Finding the right velour color is indeed a challenge, but finding it in a non-synthetic fabric is more so. I found a child's vest in a used clothing store that is the right fabric, but violet in color (like the faded edge in the center of the base above). I'll probably use that if I can't find something closer.
    I have several clocks now with this style base and I was wondering if anyone has given thought to or tried anything to treat/preserve the wood core?
    Eric
  8. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,059
    105
    El Dorado, CA
    Dyeing the fabric to the color desired is always an option, as well.
  9. etmb61
    Oct 25, 2010
    2,581
    193
    Mascoutah, IL
    Here are some better pictures. I decided to replace that strangely small disc with one from a spare pend 21 I have on hand. At least it's the correct diameter (85mm). Looks much better too.
    Eric
  10. TORSIONKID
    TORSIONKID Registered User
    May 17, 2010
    40
    Hi eric I have these very well made to spec pendulums send me a personal message if you require one.regards michael.
