Needing some information on a cuckoo clock, what's it worth ect...
Discussion in 'General Clock Discussions' started by Happyfourwheelers, Mar 1, 2020.
  1. Happyfourwheelers
    Happyfourwheelers Registered User
    Mar 1, 2020
    Hi,
    Looking for information on a cuckoo clock I picked up at an estate sale a few weeks back. Works well, other then the fact it wont stop cuckooing. I believe it just needs to be professional cleaned. And minute hand is broken off and needs to be replaced. I got a little bit of information here and there from lots of research. I was told it was made around 1865 and is a railroad style clock. I also dont believe it came with a top carving because theres no marks where it would have been. It's also a 24h clock.
    20200223_180149.jpg 20200223_180131.jpg 20200223_180144.jpg 20200223_180124.jpg 20200223_180155.jpg 20200223_180212.jpg 20200223_180219.jpg
  2. JTD
    JTD Registered User
    Sep 27, 2005
    7,490
    484
    Welcome to the board.
    We are not allowed to discuss values/worth on this part of the board. However, since you only mention the worth in the title and not the body of the message, your post would be fine if a moderator can remove the 'worth' part of the title heading.
    I am sure a moderator will be along do this for you. Other people will be able to give you the information you seek.
    JTD
  3. senhalls
    senhalls Registered User
    286
    20
    retired
    western PA.
    Closer to 1930s.
  4. woodlawndon
    woodlawndon Registered User
    Jan 18, 2017
    678
    164
    Woodlawn, Ontario
    I'm thinking 1930s or 40s. It would have had a carved crest on top that most likely would have mimicked the same type of leaves on the sides and bottom.
    Don
  5. Happyfourwheelers
    Mar 1, 2020
    Wouldnt the movement be stamped if it was from the 30's 40's. And I dont believe that it came with the topper because there is no open nail holes or glue residue on the roof where it would have been mounted.
  6. Happyfourwheelers
    Mar 1, 2020
    The hands are also hand carved. Arnt most hands in the 30's and plastic?
  7. new2clocks
    new2clocks Registered User
    NAWCC Member Sponsor
    Apr 25, 2005
    2,284
    247
    Pennsylvania
    No. There is no general correlation between trademarks on the movement and the period of the 1930s and the 1940s.
    What gave you the impression that the movement should have been marked?
    Regards.
  8. Happyfourwheelers
    Mar 1, 2020
    Seemed like most of my research in to clocks after the 1900s had a maker's mark or stamp of some sort.
  9. new2clocks
    Apr 25, 2005
    2,284
    247
    Pennsylvania
    There were many unmarked movements, especially with French and German clocks, both before and after 1900.
    Regards.
  10. Happyfourwheelers
    Mar 1, 2020
  11. Willie X
    Willie X Registered User
    12,774
    983
    I worked on a very similar clock about a year ago. It came directly from Germany in 1923.
    An early cuckoo will have a wooden frame movement and the cases are very crude with sides and back held together with wire latches. Some have no top, with the bellows exposed.
