Need Verge Assembly
GregS
492
15
Machesney Park, Illinois
I am looking for a replacement auto beat anchor assemble for a Hermle 1161-853H 114CM/60. circa '83
If you have one for sale, please reply or send me a message.
Thank you,
Greg
15,026
1,875
Greg,
You will probably be better off buying a new part, not so much 'luck' involved.
Reactions: NEW65
15,026
1,875
What RC said.
There are several versions (11 to 35mm?) basted mainly on the length of the pendulum hanger post. So you will need more information.
Last one I bought was about 25 bucks + postage.
That's a lot to spend on a 38 year old Hermle. :)
Dick Feldman
Sep 1, 2000
2,717
283
Colorado, usa
This discussion begs the question.
Why are you trying to buy a verge?
Is yours missing? Is yours nonfunctional?
Many times, escapements (verges) are blamed for clocks not running when the escapement is simply a victim of low power in the train.
Low power in the trains of a 38-year-old clock is almost inevitable.
How about a little back ground.
What is your skill level with repairing clocks?
Best,
Dick
wow
Jun 24, 2008
5,588
664
76
Pineville, La. (central La.)
Thank you,
Greg
Greg, I have this parts movement in my bone pile. If this will work, let me know.
8EAA54F2-1820-41E4-88C9-E0532431B376.jpeg D05F3A21-C76E-46D7-8E00-0C95FF3A827A.jpeg 14B80647-561E-4F14-88BC-8EEFB60B95CC.jpeg
GregS
492
15
RC, you're correct. Blackforest does show several versions of this part on their website. I just never thought of them as a Hermle parts house. Thank you.
Willie, the price seems to have gone up.... $38 - $50 now!
Dick, thanks for weighing in. I am quite confident in the time train. I did bush both sides of the escape wheel and polished all of the pivots and pivot holes. The problem is badly scored pallets (entrance and exit), which if I ground out and polished would have introduced all sorts of other geometry issues. The rest of the movement is in pretty good shape (after repairs) so this was the remaining problem. The Microset timer showed wild crazy readings with this assembly as is. I tried 'tightening' it (against Dave LaBounty's recommendation) and lost. He'll probable read this and snicker to himself, LOL.
I noticed that the pitting was all on one side, so if I moved the pallet over the escape wheel would then strike clean surfaces. Turns out I couldn't move the escape wheel because the pinion and arbor are one piece. So I thought I'd take the assemply apart and make a new arbor with the sholders moved 40 thou. The attached pic isn't great but it shows the old arbor and new one installed. The really hard part is getting the compression right. Third time I got lucky. The movement is back in test and so far looks promising.
Will, thank so much for taking the time to check you bone pile. If this doesn't pan out I'll send you a message and you can let know what you want for the part.
Cheers,
Greg
15,026
1,875
This part has to be loose in order to function. Friction varies from 7 to 45 grams at the crutch tip, depending on the clock in question.
Corrections: there are 11 different verge assemblies listed for a 1161 movement and the offsets vary from 7 to 50mm.
Current cost is about 18 to 24 bucks on open accounts.
Reactions: NEW65
NEW65
Nov 17, 2010
1,584
75
United Kingdom
Hopefully you’ll get the right verge for your movement. I have been in a similar position and it has to be right. Good luck
168,947
1,474,229
48,668
Mishellmcgee
2,955
