Need to replace or repair electric motor on my Seth Thomas model 1600 mantle clock.
Discussion in 'Electric Horology' started by rpm7653@aol.com, Apr 16, 2020.
  2. It's Coming
    Just Two More Days
  1. rpm7653@aol.com
    rpm7653@aol.com Registered User
    Jan 31, 2009
    36
    My Seth Thomas mantle clock model 1600 has an electric motor with a15 leaf cut pinion on its shaft. I would like to repair or replace. It’s not an expensive clock but a family favorite. Any suggestions?
  2. Al Dodson
    Al Dodson Registered User
    NAWCC Fellow NAWCC Brass Member
    Aug 22, 2019
    201
    53
    Columbia, PA
    If there is continuity in the coil, you do not need to replace the motor. If you do not have an ohm meter, you can plug it in and either listen for a hum or see if it has created a magnetic field. My guess is the motor is ok.
