Need to know what weights to use.
Discussion in 'Clock Repair' started by Dannob, Jul 7, 2018.
  1. Dannob
    Dannob Registered User
    Feb 20, 2009
    13
    I have a vintage Trend/Sligh wall clock that has a Kieninger movement marked 77P-80CM. I sent photos to clock works and they told me I needed on at 7.7 and on at 9.9 lbs. I ordered the only weights they had at this weight spec, and they are much longer than the 7" shell that was in the case with the movement when I got it. Now the pendulum rubs on the weights. I cannot find the size requirements for this clock and movement.
    I have the original setup card from Trend that say "Directions for movement 122" but they don't mention the weights.
    If anyone has a suggestion or can answer this question I would be greatful.
  2. Willie X
    Willie X Registered User
    12,774
    985
    I'm pretty sure the weight shells should be 160mm x 50mm on your clock, that's for a PS movement with single gong. So far I haven't found the actual weight requirement. I'm sure Mark will have the info you need, so be patient. Willie X
  3. Dannob
    Feb 20, 2009
    13
    That sounds great. You're a big help. Will wait for Mark to comment.
    Thanks again.
  4. R&A
    R&A Registered User
    Oct 21, 2008
    4,203
    107
    Are there 2 holes in the top cock? If so move the suspension spring out to the farthest hole from the movements.
    Dannob likes this.
  5. breeze
    breeze Registered User
    May 2, 2010
    86
    7
    Is the diameter greater on the new weights than the shell you got with the clock? I checked my Timesavers catalog and they list the weight requirements for the only Keininger gong movement they offer as 8.80 and 6.90. As Willie X said Mark will be along shortly.
    Breeze
  6. Dannob
    Feb 20, 2009
    13
    Yes the new weights are 60mm and the shell is 50mm. Thank you for responding.
  7. breeze
    May 2, 2010
    86
    7
    The less heavy weights will use smaller shells and this may solve your problem.
  8. TEACLOCKS
    TEACLOCKS Registered User
    Mar 22, 2005
    2,353
    77
    Clock service & repair
    Santa Rosa Calif.
    That is a PS /w gong movement, use these weights, Heaviest on time
    WEIGHT SPECIFICATIONS FOR GERMAN MOVEMENTS
    KIENINGER
    MOVEMENT CHIME DRIVE S(LBS) T(LBS) C(LBS)
    H WEST CHAIN 8.8 8.8 8.8
    HK TRIPLE CHAIN 8.8 8.8 11.0
    HTU 9-TUBE CABLE 8.8 11.0 14.5
    KK WEST CHAIN 6.6 7.7 6.6
    KKU TRIPLE CHAIN 6.6 7.7 7.7
    KSU/RSU TRIPLE CABLE 6.6 8.8 8.8
    PS BIM/BAM CABLE 8.4 8.8
    PS GONG CABLE 6.9 8.8
    RK WEST CHAIN 6.6 6.6 6.6
    RU TRIPLE CHAIN 6.6 6.6 7.7
    RWS CABLE 8.8
  9. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    NAWCC Life Member NAWCC Member
    Jul 4, 2009
    2,355
    105
    Diistributor of movements and movement parts.
    Muscatine, Iowa 52761
    PS GONG CABLE 6.9 STRIKE 8.8 TIME.
  10. Willie X
    12,774
    985
    Mark et all,
    OP posted 70P as the model #. In my book it looked like the cable drive/regular gong model # PS. So the PS came from me, right or wrong ... At 50mm the weights will have to be lead and it will probably take the longer weight shell to acomodate 8.8 pounds of lead (?).
  11. Dannob
    Feb 20, 2009
    13
    To all who replied to this thread I saw THANK YOU! I was at a loss based on the weights I have which are incorrect. Does anyone know where I can purchase the weights and sleeves?
  12. Willie X
    12,774
    985
    The 50 mm weights are usually called Grandmother weights. You might have to buy an extra lead weight and saw it off to get the 8.8 pounds. It would be best to talk to the supplier to make sure the shells are long enough to hold the 8.8 pounds. The 6.9 pounds should not be a problem.
    On this MB there are many threads on casting weights and you can also buy roofers lead in sheats and roll it up on a small mandrel.
  13. Dannob
    Feb 20, 2009
    13
    Thanks Willie X. I was able to get sleeves at Black Forest Imports. I will make my own lead inserts. Thanks agin for all the help and wisdom.
  14. Dannob
    Feb 20, 2009
    13
    Guys, I purchased weight sleeves at 50X180 and was preparing to make my own inserts. Out of frustration I called Kieninger in Germany and got the low down on the original movement
    77P-80CM. All data and knowledge has said I needed a 6.9 and 8.8 weights. Kieninger told me That my movement is their PS-movement. They are using weights with 2,7KG (5.9lb) each and 50x140 mm shells.
    I have them on order from Black Forest Imports now. I will advise how they work.
