Need to get this movement out safely
Discussion in 'Clock Repair' started by ta855, May 22, 2020 at 6:02 PM.
  2. It's Coming
    Just Two More Days
  1. ta855
    ta855 Registered User
    May 5, 2020
    12
    Hi all,
    A click spring broke/fell out of place, on my Sessions movement. The mainspring is pushing against the case. I am looking for a way to get the movement out of the case to move the click spring in place, while having the least damage to me and the clock.
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,911
    328
    watchmaker
    You could tie some wire tightly around top and bottom but not a lot can be done until you undo the screws and remove the movement. Wrap the movement in a strong but supple cloth before you attempt to remove it.
  3. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    650
    51
    Tulsa, OK
    See if you can get a big hose clamp around the spring. Jiggle the spring as you tighten the clamp and you should be able to compress the spring enough to get it out of the case.
  4. Fitzclan
    Fitzclan Registered User
    Jul 20, 2014
    632
    23
    Long Island, New York
    I find that a needle-nosed vice-grip type pliers works well in this situation. Gather as many coils as you can and lock them down so they can’t spring on you. Good luck.
  5. disciple_dan
    disciple_dan Registered User
    Mar 10, 2016
    496
    33
    Clockmaker, General Flunky
    Plant City
    Take the dial face off. get a winding key that has a hole in the tabs. Find a strong piece of wire and fashion a hook that will go into the hole on one of the tabs of the key and the other end hook onto one of the columns of the front clock plate. Put the key in a pair of vice grips and carefully wind the spring until it is free of the case and you can get to the screw on that side. Hook the wire up making sure it will hold the spring in check. With another pair of vice grips, preferably needle nose, clamp it onto the bands of the wound spring and you should be able to remove the screws. That may sound dangerous because it is a little risky. Try this only at your own risk and if you feel confident you have the wherewithal to handle it. Maybe someone has a better idea and safer too. Whatever you do, be careful.
  6. wow
    wow Registered User
    Jun 24, 2008
    3,889
    246
    Retired Music Minister
    Pineville, La. (central La.)
    Fitzclan likes this.
  7. ta855
    May 5, 2020
    12
    Thanks to everybody who has already responded. I am going to try some of these out and see what works best.
    Thank you
  8. POWERSTROKE
    POWERSTROKE Registered User
    Jan 11, 2011
    814
    54
    Can you get a strong zip tie in there to wrap the spring?
  9. Jim Hartog
    Jim Hartog Registered User
    Jan 6, 2010
    582
    33
    house husband
    Hello ta855,
    Here's another option. Home made, I call it a letdown crank. Basically, a tap wrench with a 5-6 inch handle attached. I use it as a letdown tool when I want to count the revolutions to test a spring driven clock at 8 days. 8 complete turns is roughly 8 days for a typical American clock. Comes in handy for setting up stop works on winding arbors, too.
    In your case, I would remove the dial to access the winding post. Crank the mainspring tight, and, while holding the crank with one hand, slip a mainspring retainer clamp on the tight mainspring, and then let the mainspring down into the clamp. You may want to restrain the clock case somehow, just to be sure stuff doesn't happen.
    You can never have too many tools and this one comes in handy in a variety of situations.
    Jim
    Uhralt likes this.
  10. shutterbug
    42,612
    1,097
    I use the vise grips idea, and it usually works well enough. There have been a couple where I had to cut the spring out with tin shears. $8 or so for a new spring. Sometimes it's just not worth the frustration :)
    If the click is still there, and you can turn it over, try putting pressure downward on it as you wind the spring again. That will act as the spring did, and after you let the click mate with the click wheel it will stay there without your help.
