American Need Strike 2nd Wheel for Waterbury Mantle Clock Patented 1891
bbwatch
Dec 25, 2002
270
My lathe didn't line up well and I ended up drilling a new pivot hole for strike second wheel off center. Looking for a movement ( or the appropriate wheel). Anyone able to help? Trying to keep costs down so don't want to replace arbor.
The movement is 65 mm wide and 106 mm high. The wheel is 26.19 diameter, arbor is 23.6 mm, arbor diameter is 1.79 mm and the pivot should be 1.15 mm dia. Don't need the movement, just the wheel, but I would be willing to pay for the movement.
Any takers can contact me at bbwatch@verizon.net
Barry B
waterbury case.jpg movt front.jpg movt rear.jpg patent date 1891.jpg strike second wheel off center pivot hole.jpg
13,729
1,409
Finish the pivot job as is (off center) and then turn the pivot to center. Use a steel that's not to hard. I often use finishing nails. Their qualities are very close to the wire used in old American clocks.
WIllie X
46,395
1,851
Yes. You may have to enlarge the hole for a larger pivot, then use the lathe to cut it down to size as Willie says. It will center itself as you reduce the thickness.
lpbp
NAWCC Star Fellow
NAWCC Life Member
Aug 25, 2000
2,973
62
When I get home, I think I have a movement that can be parted out, if it"s right maybe I can just sell you the whole movement for nominal cost.
bbwatch
Dec 25, 2002
270
Thanks, LPBP. I may need it. I'm trying to cap it right now. Let me know about the movmt. Barry
165,349
1,439,160
86,162
Evocatas
2,873
