Need spring help for French carriage clock
Discussion in 'Clock Repair' started by heifetz17, Mar 16, 2020.
  1. heifetz17
    heifetz17 Registered User
    Apr 8, 2015
    209
    I'm restoring this old carriage clock and the strike spring is broken, and I'm having trouble locating the proper sized spring. I don't know how long the spring is either as I currently don't have (but am ordering!) the tool to get the spring into/out of the barrel...
    Not that the tool matters much when the spring is broken!
    Any tips?
  2. Uhralt
    Uhralt Registered User
    4,809
    560
    You don't need a tool to get the broken spring out of the barrel. Just take a pair of needle nose pliers, grab the inner end of the spring and pull it out of the barrel. Wear gloves for that. Then measure the length of the spring.
  3. heifetz17
    Apr 8, 2015
    209
    I'll do that tonight. I'm looking at springs in the meantime and the closest width I can find is 5/8, which is about .012 narrower that my spring. Will that cause me any problems inside the barrel?
  4. shutterbug
    43,233
    1,191
    I don't think it will cause much of a problem. That's a pretty small difference.
  5. heifetz17
    Apr 8, 2015
    209
    The broken spring measures 34.5 inches long, and the closest I can find is MS164 from Merritt's at 39.5 inches. Will that extra 5 inches cause any issues? Also, my smallest spring sleeve is 1 inch which is the exact diameter of the barrel, so the sleeve won't fit inside for installing the new spring. Is it possible to accomplish this by hand similar to a watch mainspring?
  6. Uhralt
    4,809
    560
    I don't think it will create a problem. These clocks usually run several days longer than a week, or, if they don't, they have a stop work that limits runtime. In both cases, the clock will still run a good week between windings. It is possible to insert the spring by hand. you can also easily make a suitable sleeve form a piece of copper pipe from the plumbing department of a hardware store. You will probably find other uses for it later on.
