Need some help with a tall case mission clock
Discussion in 'Clock Repair' started by shutterbug, Jan 26, 2018.
  1. shutterbug
    40,296
    631
    I got this mission clock movement in. It was very rusted up, had no hanger or pendulum and no springs. I finished it up today, and it's doing fine .... but I don't know what pendulum is needed or how it hooks up. The movement has no markings, but looks like an ST 89 time and strike half deadbeat. Any help?
  2. Willie X
    Willie X Registered User
    11,754
    609
    Bugs,
    They are fixed up just like an old store clock. Brass faced, or plain, cast iron bob with a cast strap, or tunnel, for the stick to go through. The stick has a rectangular cross section to fit the pendulum, usually 5/8" wide and somewhere between 1/4 and 5/16" thick. Good luck, Willie X
  3. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    140
    deceased
    Pictures needed to be of much help.
  4. shutterbug
    40,296
    631
    #4 shutterbug, Jan 26, 2018
    OK. Here's the movement after cleaning it up a bit. I just hung a suspension from stock on it.
  5. David S
    David S Registered User
    Dec 18, 2011
    7,101
    190
    Brockville, On Canada
    Shutterbug what are all those chicken scratches in a rectangular shape at the bottom center of the plate?
    David
  6. Willie X
    11,754
    609
    Possibly an Ingraham. Those wierd punchings are probably hiding the brand ... a debranded movement?
  7. lpbp
    lpbp Registered User
    NAWCC Star Fellow NAWCC Life Member
    Aug 25, 2000
    2,830
    25
    Looks like a Gilbert to me.
  8. Chris D
    Chris D Registered User
    Sep 8, 2009
    411
    Coplay, PA
    Does the case look like this? I have one, Seth Thomas movement. Unfortunately mine has a rigged crutch and replacement pendulum and stick, so probably not much help. It runs fine but sounds horrible. Haven't had the time to try and fix it, so it just collects dust in my basement.
  9. Chris D
    Sep 8, 2009
    411
    Coplay, PA
  10. Willie X
    11,754
    609
    I think Ipbp is right. That count wheel looks Gilbert. The dead beat escapement is more common with Ingraham but Gilbert probably used that type too.
  11. shutterbug
    40,296
    631
    Thanks for that! Anyone have a Gilbert with a pendulum on it? :) I was a bit upset to see the brand obliterated too!
  12. Dave T
    Dave T Registered User
    Dec 8, 2011
    2,618
    66
    retired accountant
    NC
    #12 Dave T, Jan 27, 2018
    I'm thinking this is a Seth Thomas 44.
    Forget that, I was looking at post #9.
  13. harold bain
    40,850
    140
    deceased
    I have a Gilbert San Jose with that movement, made in 1926. Has a small triangular shape end on the end of the suspension rod and a small hook on the pendulum
  14. Steven Thornberry
    Jan 15, 2004
    20,976
    660
    Ne’er do well
    Here and there
    And the Ingraham count wheel is in a different position, about the same place the count wheel is on the ST #44 in post 9 The 34 on the left leg of shut's movement indicates 1934. I seem to recall having seen that obliteration before on Gilbert movements, but, IIRC, on Gilbert movements sold to Welch in 1899/1900 after the fire at the Welch movement shop. Curious.
  15. shutterbug
    40,296
    631
    Thanks guys! Harold, how long is the pendulum on yours? I was thinking it was a seconds beat, but after seeing some pics, am no longer so sure.
  16. Chris D
    Sep 8, 2009
    411
    Coplay, PA
    I have a Gilbert San Remo, probably very similar to The San Jose. Pendulum is 12" top to bottom.
    [/ATTACH] 15171737007708926623457307979541.jpg 15171737509352586922290528792962.jpg 15171738089696617958096658227716.jpg 15171738852832934369010582774505.jpg
  17. harold bain
    40,850
    140
    deceased
    Looks the same as mine for size, Chris. You might need to do some experimenting to figure out the final length.
  18. shutterbug
    40,296
    631
    This one goes in a tall case. I should have counted teeth when I had it apart. :mallet:
  19. shutterbug
    40,296
    631
    Some days I just amaze myself! I put a long pendulum on this movement, and let it run 24 hours. By looking at the count wheel, I could tell it had lost about 5 hours in 24. Doing a quick calculation, I determined that the pendulum had to be about a foot shorter. I have seen pic's of these clocks with short pendulums, so I went ahead and cut the stick shorter. After running it a couple of hours I noticed that the strike side was hanging up! So now I have to get another pendulum stick!!! :glasses::banghead:
  20. Willie X
    11,754
    609
    Well, everyone has a box of short sticks! Tape Man ... uses da tape, sneak up on it, like stalking a wild pig. Guess you were distracted by that calculation. :)
    Willie
