Most visitors online was 1990 , on 7 Feb 2022
Thanks I've been setting it to 7 and letting it run till it stops then doing it again.Welcome to the forum!! Beautiful watch.So the hour hand is either bent or misaligned. Is it hitting enough to stop the watch? If so the watch may be wound all the way and can't wind down cause it only runs a short time.
I'm pretty new to and I'm sure someone will be along shortly to help you out.
Heres a better picture. Sorry my camera isn't the greatest.The hour hand keeps hitting second hand. Watch is running but stem won't wind. I haven't wound it because it's so tight you can feel push back when turning it. Wanted to know if this is the correct dial or hands. I know it's not the original. New to site and new to watches.
View attachment 710209 View attachment 710210
Thank you RobMoving thread to watch repair section for best results.
Rob
Thank you, any info helps and greatly appreciated. It's in an after market salesman display by cwcc. It's a M1899 1901 ball Waltham offical std 16s 19j S/N B0554350. The ORS dial? Is that single or double sunk?Welcome to the forum. No, it's not the original dial. It should be a "Ball", probably "Official RR Standard", marked dial. And yes, it does sound like either the hour hand was pressed down to far or the seconds hand is not down far enough. One must be careful when dealing with the seconds hand in particular, as you can break or bend the seconds hand post without too much effort. Aligning hands can be a bit fiddly, as they do find many ways of fouling. Sometimes you do have to bend them a bit, but that too is rife with some hazards, as they are rather delicate.
The lever for setting looks like the type Waltham used on 1872 models. I don't remember them being like that on the Ball models, but maybe...I have to run or I'd do more checking on that. Maybe later if nobody else chimes in about it.
Oh, and it looks like the watch is in a Hamilton BOC (Bar Over Crown) style case, FWIW. They usually house a movement like a Hamilton 992B. Cheers.
Thanks randy, I haven't wound it at all. It was to tight once I felt resistance I didn't mess with it. Im searching for someone to service it in my area. No luck yet.You need to have this movement serviced. That should at least get you going in the right direction.
Dial and hands can be addressed, changed at the same time if needed or desired.
Running a nice watch with old lubrication is a quick way to destroy it.
From your description,..the mainspring and "works" are binding...you could actually break the spring if you keep winding it.
Randy
Thanks im new to the site and new to watches. Im trying to learn as much as I can. And where better to do that then here. With such great people with so much knowledge. Keep it coming guys and thanks againIf you can't wind it at all even after letting it run down a bit, then yes, you probably have some sort of problem with the clutch and/or winding pinion. But if you can get it to wind after running it down it bit, the mainspring is probably just completely wound and just hasn't run down enough to get a lot of winds back in the barrel. It does sound as if you've run it down enough to be able to get some winds on it though.
I don't remember if the Ball models are 1899 Walthams with a different plate layout. If so, then you might have a fairly easy time getting parts, should you need them. Good luck.
Quick update, it's winding. Now to get it serviced and find original case and dial and hands. If anyone has any parts please let me know. ThanksThe hour hand keeps hitting second hand. Watch is running but stem won't wind. I haven't wound it because it's so tight you can feel push back when turning it. Wanted to know if this is the correct dial or hands. I know it's not the original. New to site and new to watches.
