Need Information on a Bulova Lip-like Movement
Discussion in 'Electric Horology' started by TockDoc, Nov 6, 2019.
  1. TockDoc
    TockDoc New Member
    Nov 6, 2019
    This is a smaller 1.5v movement used in the back of table picture (shows a small clock in front). Trying to repair but can find no information on how it works! Any ideas or links to data? Looks very simple, but the balance wheel will not oscillate. Thanks folks!
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,494
    210
    watchmaker
    19 AO is the Bulova calibre #.
    I'd be checking the resistance of those coils. somebody has resoldered the connections one one of them.
  3. Chris Radek
    Chris Radek Registered User
    Apr 13, 2014
    465
    142
    Watchmaker (now accepting new customers)
    Lincoln, NE, USA
    Test that carbon comp resistor too...
    This is dated 1965 so the coils might be the same 15 micron wire they were using in Accutrons.
    Is the balance free? It should oscillate a few times and advance the clock on a good puff of air. If yes, the problem is electric; if no, the problem is mechanical (and also maybe electric...)
  4. praezis
    praezis Registered User
    Feb 11, 2008
    416
    15
    Germany
    Movement is Ebauches SA cal. 9000.
    Bph = 18000
    It is controlled by a mechanical contact that can be an issue, too.
    Frank
  5. TockDoc
    TockDoc New Member
    Nov 6, 2019
    These are super comments! Thanks so much. Coils good, 2.2K good. Wiring good. Balance wheel free and will oscillate freely until it is attracted to one of the coils. Culprit seems to be corroded balance wheel contacts, as suggested. Again, thanks folks! Your a good group of expertise. (~8
