Need help with silk suspension
Discussion in 'Clock Repair' started by heifetz17, Jun 28, 2020.
  1. heifetz17
    heifetz17 Registered User
    Apr 8, 2015
    209
    Hey guys, this is an 1850s French movement and my first time working with a silk suspension. Can someone point me in the right direction on where to find a replacement and how to repair it? These pictures are before my overhaul, so the movement has already been cleaned and oiled and is now functional, I just need to replace the suspension. Does this require a special pendulum bob?
    Also it’s missing the chime. Would this have been just a bell like normal?
    View attachment 597889 View attachment 597890
    69697322-9E2C-4801-A847-3FD7A8E55258.jpeg B5EB3635-AAF3-4F9E-AFC0-BAC5C1713D8B.jpeg
  2. Uhralt
    Uhralt Registered User
    4,804
    560
    Can't view your pictures.
  3. JTD
    JTD Registered User
    Sep 27, 2005
    7,466
    470
    The 'silk suspension' is just a loop of thread (nowadays usually cotton). One end of the thread is fixed to the static post and the other loops round the moveable post, to form a loop for the pendulum to be hung from. The loop can be shortened or lengthened by turning the moveable post, to get the timekeeping right.
    It would have had the usual French pendulum which you can get from the clock supplies companies.
    Yes, the strike would have been on a bell. These are also available to buy.
    JTD
    PS Your pictures are showing now, at least I can see them.
  4. Jaap
    Jaap Registered User
    Mar 6, 2013
    106
    12
    You can use the dental floss from jordan.
  5. JTD
    JTD Registered User
    Sep 27, 2005
    7,466
    470
    I suppose you can, but I think it is rather thick. I prefer to use button thread, which is very strong but also thin.
    But it is a matter of what you like best, I suppose.
    JTD
  6. R. Croswell
    R. Croswell Registered User
    10,209
    821
    I use Spidrwire, which is a thin Kevlar fishing line. Unaffected by humidity.
  7. Kevin W.
    Kevin W. Registered User
    22,352
    337
    That is a good recomendation Robert, the spider wire.
  8. heifetz17
    Apr 8, 2015
    209
    Thanks everyone! I’ll look into the spider wire for sure!
  9. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    3,276
    360
    Science teacher, writer
    Lancaster, Ohio, USA
    The only difficulty with Spyderwire is that the stuff is manufactured on the Planet Krypton: you can't cut it without a major effort. It's fine to use otherwise because it's a bit stiff, so it threads through holes and knots easily enough, but then you have to cut it off or you'll be sending the clock back home with a roll of fish line as an accessory. Wire cutters: nope. Pocket knife: nope. Razor blade: not really. I forgot how I finally got it cut.
    Now I have a whole roll of it minus five inches. It would make a great trip wire.
    Royce likes this.
  10. JTD
    JTD Registered User
    Sep 27, 2005
    7,466
    470
    I guess it's every man for himself, but I'm sticking to button thread. Super strong and never had a problem with it.
    JTD
  11. kinsler33
    Aug 17, 2014
    3,276
    360
    I think I like your button thread, too. I just never knew what it was called. I'll inquire at JoAnn Fabrics, whose patient ladies have endured me for many years now in my searches for crochet hooks (splendid for helper springs) and assorted craft supplies that I mis-use for clock repair.
  12. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,762
    594
    According to the Internet of things, ceramic scissors work well. Blades can be brittle though.
  13. R. Croswell
    10,209
    821
    You must not be using the same product that I use. What I have is braided and green in color. It is quite limp and flexible. No problem cutting with a new single edge razor blade or a good sharp pair of scissors. The only difficulty is if you don't get a good clean cut it is hard to poke through a tiny hole. As you can see, the end cut clean with a razor blade.
  14. Ralph
    Ralph Registered User
    NAWCC Member Sponsor
    Jan 22, 2002
    4,835
    125
    What's wrong with silk thread?
  15. R. Croswell
    10,209
    821
    Nothing that I know of.
  16. shutterbug
    43,154
    1,182
    I think the bell post is intact. If you're missing the bell you could probably find one on Ebay. Just measure the distance from the post to the hammer for an approximate radius.
  17. kinsler33
    Aug 17, 2014
    3,276
    360
    Note that when you're done with your silk-thread suspension you'll have a pendulum that doesn't behave very well. It'll swing, but it'll wobble. That, I think, is why these were replaced by suspension springs, which I didn't appreciate prior to dealing with silk thread suspensions.
  18. R. Croswell
    10,209
    821
    I've never found that with this type of suspension. Pendulum wobble is most often caused by something not lined up perpendicular one straight in line with the swing.
  19. kinsler33
    Aug 17, 2014
    3,276
    360
    Hmm. I had a miserable time with the things. They seem to settle down okay. I'll ask for instructions if one ever comes by again. Thanks.
    Mark Kinsler
  20. Uhralt
    4,804
    560
    They usually wobble for a while after you pushed to start the pendulum. After a while the pendulum will swing fine if the crutch is perpendicular to the pendulum rod.
  21. Jaap
    Mar 6, 2013
    106
    12
    #21 Jaap, Jul 1, 2020 at 3:22 PM
    A tiny drop of superglue at the end will help.
    Kevlar 250 lb braided fishing line 1mm thick works great for fusee clocks.
  22. shutterbug
    43,154
    1,182
    Sometimes cutting with a hot blade will solve the issue too.
