deloid
I don't typically restore clocks made after 1950 or so. I am doing this as a favor to another repairman.
This St. Aubin clock (I think 1970's) is now cleaned & prepped in the typical manner. The strike train is fine but the time side is sluggish. All bushings and pivots are perfect. The only area that I can isolate and feel too much drag is between the mainspring barel and the second wheel. The barrel is fine, the second wheel pivot is straight and highly polished. The other side of the second wheel has a pinion that fits completely through the plate and is held by a widened arbor that is also highly polished. It seems to me that the drag is completely coming from the large pinion bearing on the plate.
I don't know these clocks but I wonder if this may have called for a heavier oil like Moebius D5. I tried it dry and with a light clock oil...a bit better with light oil but not enough.
I'm hoping someone here knows this system and what the proper lubrication might be and if I may be missing something.
