Need Help with ITR Time Clock Day/Time Unit Dissassembly
Discussion in 'Clock Repair' started by Bates, Jul 16, 2017.
  1. Bates
    Bates Registered User
    Feb 6, 2013
    45
    Hello,
    i can't figure out how to remove the shaft from the date/time unit of a 1925 ITR time clock I'm trying to disassemble for cleaning. I've gotten most of the unit apart including the top part, which has the day, hour, and minute wheels, but I can't figure out how the shaft that turns with the lever is removed. It seems to have large pins which may used to hold it but I'm not sure that's what they are. If any have worked on one of these units before and removed the shaft, can you let me know how it can be removed. I've attached some photos that will hopefully help. The pins I'm referring to are not the cotter pins you may see in the photos. Rather, they are the round protrusions from the shaft.
    thanks
    Bates
  2. the 3rd dwarve
    the 3rd dwarve Registered User
    Nov 3, 2000
    598
    Bates
    The protruding pins look like they run through the sleeve and shaft holding the two together. Measure the diameter of the end of the pins. If one is larger than the other that is a dead giveaway that the pins are indeed holding the two pieces together. If you are going to drive them out make a saddle to support the sleeve by drilling a hole in a piece of two by four the same diameter as the sleeve and then cut it in half. Drill a perpendicular hole for the pin so you can lay the sleeve in the saddle and drive the pin out.
    D~
  3. Bates
    Feb 6, 2013
    45
    D~,
    You were exactly right. I was able to drive the pins out after some coaxing with a solvent to break down some of the dirt and oil that was encrusted around them. Your suggestion gave me confidence in knowing they were pins and in knowing which way to drive them.
    Thank you very much
    Bates
  4. the 3rd dwarve
    Nov 3, 2000
    598
    Hi Bates,
    Success! I love it when a plan comes together.
    You're very welcome, I would like to see some pictures when your work is complete.
    D~
Similar Threads - Need Help Clock Forum Date
Need some help with a Waterbury Open Escapement clock Clock Repair Oct 7, 2017
Need help with Waterbury Faux Mercury Pendulum Mantel Clock Clock Repair Aug 1, 2017
Need help with newer Swiss clock Clock Repair Jun 19, 2017
Swiss? German?? Need help identifying wall clock and repair questions Clock Repair Apr 30, 2017
Need help with a 4.5 inch Chelsea clock Clock Repair Mar 27, 2017
