Need Help - Older GB
manfromblan
Jan 29, 2005
88
Blanchester, Ohio
Not sure of how to correctly mount the top suspension block onto the saddle. Is something missing here?
Do I need to make spacers to hold top block in place?
According to the serial # this clock is 1907/08
Thanks Wayne
16862319983474937135837206698364.jpg 16862320387702021993049728968000.jpg 16862320669061306068472333546465.jpg
etmb61
Oct 25, 2010
3,409
563
Mascoutah, IL
Hi Wayne,
The top block should have a pin that sits in the groove at the top of the bracket so the suspension can pivot front to back. The block itself was originally wider to fill the entire space so you would want to take up the extra space you have. The screw on the side keeps it in place once you have the clock set up.
Here is an old photo of one of mine.
Eric
KurtinSA
Nov 24, 2014
6,125
711
San Antonio, TX
Certainly Eric has it right. Someone tried to use a smaller block to try and get the clock going. According to John Hubby's data, the clock dates to the last half of 1910.
Kurt
Dells
Oct 18, 2019
1,141
384
In the cotswolds UK
It’s relatively easy to make a top block, superglue 2 bits of brass together, mill or file to size , drill the 2 holes for screws and countersink one side then tap holes , drill hole for snug fit for pin , heat to release both bits , then the part with the countersinks in broach or drill slightly larger , make or purchase some small screws, the picture is of a top block I made for a torsion clock , although these are different the principle is the same except this one has a round part on it turned in the lathe while the 2 bits of brass were still glued together.
Staff online
183,852
1,605,767
55,917
Mommia
3,190
Watch case by Kent
Top Bottom
