A friend needs help in identifying this clock. He has owned it for about 40 years. It has what appears to be an unmarked Waltham movement with the # 5600 on it....
....No other markings on this clock. No signature on it anywhere. It does have a black seat board behind the movement that enables the movement to be mounted to this rather than the back of the clock case. This black seat board is glued to the back board...It also has what I would refer to as a "Willard Type" of door latches that can be seen in the pictures
It is a full size Lyre....
You can contact me through this blog or call me 916-952-4961
Thank you,
Vince
Thank you,
Vince
