Need help identifying French clock movement
Brucethedude
Apr 18, 2022
96
22
Hi I was hoping to get some information on a clock movement I have. I searched online and can’t find a true match.
It has no stamps just the numbers 972 and 72 on the backplate and a 972 with an F on the front plate.
Any help is appreciated.
roughbarked
Dec 2, 2016
1,399
752
Brucethedude
Apr 18, 2022
96
22
If you do a search there is stuff to learn.
Roughly your clock is likely about 1850. Could be earlier or later for these were made for a long period.
Thanks but I was mostly looking for anything on brand or design since I know it’s missing a few parts.
It’s for a client who eats it fixed and trying all avenues before I tell him I can’t get the parts.
Brucethedude
Apr 18, 2022
96
22
Maybe someone from the nearest NAWCC chapter can help you with your search for parts. I'm reasonably sure that enough of these were made for a donor movement to still be around.
Probably I was just hoping for a name or something to make the search easier.
Thanks nonetheless
zedric
Aug 8, 2012
2,308
649
Just to back up what roughbarked is saying, even if you were able to find who made the movement, and were then able to find someone else who also knew who the maker was and who might have access to a spare movement with donor parts by that maker, there is no guarantee that these would fit - the bell and bell stand would almost certainly be OK, but the racks and other parts, there is just no guarantee that these would be a drop in fit. You might be better off looking for a complete movement, or if you have the skills to adjust the parts, a donor movement may be able to be found eventually. For example, if it were a Japy movement, Japy made thousands of different designs over the course of 100 years or more of manufacturing.
Brucethedude
Apr 18, 2022
96
22
Thanks that’s what I thought but I thought I’d try just to say I did
Beckelman
Jul 25, 2021
11
66
It just so happens that I'm working on a clock right now that has almost this exact same movement. On the back plate there is a stamp that says "MAROUE DEPOSEE". Over the past year I've had 3 other of these types of movements but this is the only one that is stamped. Also, (you may already know this) the case is called a "Slate Clock". Hope that helps with your search
Brucethedude
Apr 18, 2022
96
22
Wow! Thanks I really didn’t know anything about it and just thought I’d throw it out here and now I’m happy I did
new2clocks
Apr 25, 2005
5,079
1,150
Pennsylvania
'Marque Deposee' means 'Trademark' in English.
Usually, a logo is attached to Marque Deposee to indicate that the logo is a registered trademark.
Mikrolisk shows well over 100 clock and watch trademarks with 'Marque Deposee' as part of the trademark.
If you show a picture of the logo, perhaps we can tell you who owned the trademark and presumably made the movement.
Regards.
Staff online
184,018
1,607,282
55,997
MaryLouLou
3,195
Top Bottom
