Need help identifying French alabaster clock
Discussion in 'Your Newest Clock Acquisition' started by Rockin Ronnie, Mar 4, 2017.
  1. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    819
    [​IMG][​IMG][​IMG]
    Need a little help identifying this Alabaster shelf clock. I believe it is French. I am having trouble getting a clear shot of the trademark since the gong and crutch are in the way but I hope a partial capture of the trademark will help with an ID. It is something...Deposee. If not I can take the movement out of it's case. The movement is removed by a number of bolts on the bottom of the case. Under the trademark are the numbers 3851 on left side of the back plate and 55 on the right. The clock is 11 inches high by 8 inches wide by 5 inches deep. Approximate age?
    The clock is not without it's issues. The strike side does not work. I can feel the tension of the spring when I put the key in the arbor but the spring does not engage - there is no clicking. There are one or two issues with the case that I will address in the Case Restoration forum. Otherwise the time side is working nicely.
    It is very heavy.
    Ron
    Attached Files: Download all post attachments
  2. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    1,592
    Note that the term "Marque Deposee" is French for trademark. So, more information is needed. You might search the forum for "Deposee" and see what pops that is similar.
    Kurt
  3. Rockin Ronnie
    Nov 18, 2012
    819
    Thanks Kurt, I also just realized that when I did a Google translate. Marti seems to come up a lot when I search the forum. Would these two photos help?
    [​IMG][​IMG]
    Ron
  4. Andy Dervan
    Andy Dervan Registered User
    Oct 23, 2002
    2,244
    Hi Ronnie,
    You may have to remove the gong block to see the company's trademark.
    The early clocks were actually made from Belgium slate.
    Andy Dervan
  5. Ticktocktime100
    Ticktocktime100 Registered User
    Nov 11, 2012
    844
    Hi,
    The approximate date of the clock is 1880-1900. We will need to see that stamp clearly in order to identify the manufacturer.
    Regards.
  6. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    3,603
    It is a French marble clock probably late 19th C. I used to own a clock with the same mark on the backplate but I was never able to attribute it to any maker. The 5 5 is the pendulum length as in 5 and 5/12 French inches.
  7. Rockin Ronnie
    Nov 18, 2012
    819
    Thanks Jonathan and Ticktocktime100.
    I also discovered that taking the movement out of the case requires undoing the two screws that go through the back bezel into the brass straps that protrude through the case from the front bezel. Andy suggests the gong block as a possible location of the maker's mark. I may take the movement out to have a look. The numbers, 3851, on the back plate are identical to the numbers on the pendulum.
    Ron
  8. JTD
    JTD Registered User
    Sep 27, 2005
    3,863
    12
    I think Andy meant that you would have to move the gong block in order to see the maker's mark on the back plate of the movement.
    If you just loosen the nut on the bottom of the case you can swing the gong out of the way, if you don't want to take out out.
    Yes, to remove the movement, you just undo the two screws that hold the straps and then pull the movement out from the front.
    JTD
  9. Rockin Ronnie
    Nov 18, 2012
    819
    Yes, I realize that now.
Similar Threads - Need help identifying Forum Date
Need Help Identifying Recent purchase - Thought to be HAC Your Newest Clock Acquisition Mar 5, 2017
Latest find - Vienna Regulator 1 weight - need help Identifying maker Your Newest Clock Acquisition Jun 4, 2016
Need help identifying a grandfather clock Your Newest Clock Acquisition May 6, 2016
Need help in identifying 2 clocks Your Newest Clock Acquisition Oct 17, 2015
Need help identifying Ridgeway Grandfather clock Your Newest Clock Acquisition Jul 22, 2015
