Need Hamilton 970 parts
Discussion in 'Watch Repair' started by shuman, Sep 11, 2019.
  1. shuman
    shuman Registered User
    May 15, 2008
    60
    I have a Hamilton 970 which has incorrect winding and setting parts. The squared shaft on which the winding and setting gears slide doesn't fit at all. Also, half of the headless retaining screw that retains the stem is broken off. Given that the 970 is not a common watch, finding a parts movement seems unlikely. Are there any more common models that have compatible parts?
    Thanks,
    Dave
  2. John Cote
    John Cote Director
    Director NAWCC Member
    Aug 26, 2000
    4,262
    621
    Photographer
    Midwest USA
    I will look in my junk movement drawer Dave. If I have a movement or not I will let you know.
  3. Jim Haney
    Jim Haney Registered User
    Sep 21, 2002
    6,553
    1,189
    Working the farm, Garden,horses, goats, chickens,
    Decatur, TN.
    What is the serial number because they have different parts depending on the age of it.
  4. shuman
    May 15, 2008
    60
    Hi - the movement is 300381. pocketwatchdatabase says it was finished in 1903,
    Dave
  5. Jim Haney
    Sep 21, 2002
    6,553
    1,189
    Decatur, TN.
    OK, So you need the parts for a OF Detent set system. Most the detent set Hamilton watches are the same . Send me a Private message about them
  6. shuman
    May 15, 2008
    60
    Pardon my ignorance - I don't see how to send a private message
    Dave
  7. Jim Haney
    Sep 21, 2002
    6,553
    1,189
    Decatur, TN.
    When I click on your name a box will appear, then right under your Member since May 15 2008, it says start a conservation and click on it( Under My Name)
  8. shuman
    May 15, 2008
    60
    I don't think I have the same format, or I'm looking in the wrong place. I can see your profile page but no "start a conversation" or "member since" or similar.
    This watch is the one I bought from you at Wilmington.
    I see that the squared shaft is long enough to sit in the pillar plate so it's properly supported at both ends but the sliding gears take up too much of the shaft length, and the inner pivot on the squared shaft is covered by the setting gear.
    What other information can I give you?
    970-wind-set-1-cropped.JPG 970-wind-set-2-cropped.JPG 970-wind-set-3-cropped.JPG 970-wind-set-4-cropped.JPG
  9. Jim Haney
    Sep 21, 2002
    6,553
    1,189
    Decatur, TN.
    That is not a detent stem Hamilton System. It is a regular clutch stem system. You may need a spring that goes in the grove of the clutch in the 1st picture
