Need E Howard Crank Dimensions
Discussion in 'Tower, Monumental & Street Clocks' started by sjaffe, Feb 28, 2019.
  1. sjaffe
    sjaffe Registered User
    Dec 25, 2012
    421
    Engineer
    Santa Rosa,CA
    Hello,
    I'm (still) working on an E. Howard tower clock (circa 1908). You may recall the winding crank has gone AWOL and I've been trying to find a substitute. I have located an expert blacksmith/welder who is willing to help fabricate a new one. The only solid information I have is the winding arbor end is 5/8" square. Could someone provide enough information so we can make a new one? I need how deep to make the square fitting over the winding arbor end, and how long each of the three sections need to be (arbor end, 90 degree piece and handle section).
    Thank you,
    Stan
  2. Eric Ryback
    Eric Ryback Registered User
    NAWCC Brass Member
    Feb 4, 2013
    40
    7
    Saint Louis, MO
    There is a crank on Ebay. "Antique Tower Clock Cast Iron Winding Hand Crank 12 5/8" Long 1/2" or 13mm Hole" You could file the square to fit the 5/8" square winding arbor.
    Good Luck! Eric
  3. Paul M
    Paul M Registered User
    May 1, 2018
    46
    Stan, I just saw your post. Are you still in need of crank dimensions? The photo below shows our 1906 E. Howard Model 0 clock with its crank at the base.
    - Paul -
  4. sjaffe
    Dec 25, 2012
    421
    Engineer
    Santa Rosa,CA
    Thanks Paul. I was able to get dimensions of a similar tower clock crank and we made one up. I would still like to get the dimensions of your crank for comparison. I measured the square end of the winding arbor as 5/8" and we made the crank to fit this, but when I tried it it did not fit. I had just used a tape measure instead of calipers so guess it is slightly beyond 0.625". Could you tell me what your's measures at? My access is somewhat limited. I'm not sure if ours is actually slightly larger than 5/8" or if the end might be mushroomed slightly and that is what is keeping it from working correctly.
    Stan
