Need advice removing L&R Master center column.
Discussion in 'Horological Tools' started by bchaps, Oct 16, 2009.
  1. bchaps
    bchaps Registered User
    Dec 16, 2001
    1,130
    14
    Mountain Top, PA
    I purchased a L&R Master cleaning machine that appears to have been stored outdoors for the past 10 years. Other than superficial dirt on the unit, the center column has some rust which will be easier cleaned if it can be removed. I see two pins that appear to have been driven through the aluminum housing into the steel column base. Before taking punch and hammer to the pins, I would prefer to hear from someone who has removed a center column already. Will the pins drive though?...or are they tapered and must be driven back out from the inside?
    Thanks...
