Need advice on a vintage 8 day clock
Discussion in 'General Clock Discussions' started by Tom L., May 10, 2018.
  1. Tom L.
    Tom L. New Member
    May 10, 2018
    I've recently begun to collect a few clocks, and my wife added the pictured clock this past week.
    I have not tested it as yet to see if it works correctly, but gave it a quick clean-up.
    I pulled the 'ring' on the back left as shown in photo 2 to see what it does, but it appears it has disconnected the clock movement? - something is moving around inside that wasn't before.
    I need to confirm the to open this clock that I would remove the three front bolts and remove the hands.
    Any help to a rookie would be much appreciated!
  2. Uhralt
    Uhralt Registered User
    4,108
    423
    Yes, you need to remove the hands first and then remove the front screws. The face of the clock will come off and you can access the movement. I believe the ring you pulled is to start the balance wheel (or pendulum if the clock has a short pendulum) after winding the clock if for some reason the clock has stopped before winding. You will see what it is when you open the clock.
    Good luck.
  3. stewey
    stewey Registered User
    Dec 20, 2012
    1,017
    14
    Oshawa, Ontario.
    After you have done what Uhralt suggested, take a photo of the movement and post it here...We would be interested to see what you have.
  4. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,482
    92
    retired educator
    Greenfield, Nova Scotia
    Looks like a Forestville plate clock. You might have a time only movement that looks like this. The wire could be connected to a speed adjuster.
  5. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,590
    233
    watchmaker
    The back plate cover can be lifted off to see the movement. The three screws do need to be removed to separate the movement from the plate as described. Nice plate. Unusual for me to see one of that design.
  6. Uhralt
    4,108
    423
    Interesting. What holds the back cover in place? Is it just friction?
  7. roughbarked
    Dec 2, 2016
    3,590
    233
    watchmaker
    Yes. It is pressed in like the lid of a can. As far as I can see from here it looks to be this type.
  8. Tom L.
    Tom L. New Member
    May 10, 2018
    Thanks for the replies!
    Well - here are some photos of what I have to deal with - showing both sides of the movement. I see no maker's markings on the movement.
  9. Rockin Ronnie
    Nov 18, 2012
    1,482
    92
    retired educator
    I have a couple of shelf clocks with that movement. Mine are not marked but I suspect they are German. Easy to work on, tough to get just right to run.
    Ron
  10. Uhralt
    4,108
    423
    As I suspected, the ring is connected to a lever to give the pendulum a push to start the clock going.
  11. Tom L.
    Tom L. New Member
    May 10, 2018
    Thanks, guys, for all the help. The clock is up and running!
  12. Uhralt
    4,108
    423
    Great, that was quick and painless!
