Neat watch made with Taig Lathe
Discussion in 'Horological Tools' started by Kevin W., Oct 9, 2009.
  1. Kevin W.
    Kevin W. Registered User
    22,596
    386
  2. RunesS
    RunesS Registered User
    Jun 29, 2005
    183
    Hillerød, Denmark
    He "only" made the case and buckle, right? I mean he didn't make the movement, hands and dial, did he?
    Best Regards Rune B
  3. Dave B
    Dave B Banned
    Jun 7, 2008
    2,389
    Civil Engineer; woodwind musician; clock repairman
    Westminster. MD
    According to the caption, he made everything except the screws. One presumes that includes the entire movement, as well. Although, I tend to wonder if he made the jewels.
  4. Ralph
    Ralph Registered User
    NAWCC Member Sponsor
    Jan 22, 2002
    4,927
    142
    Did he make it for Shreve Crump & Low of Boston, which appears to be what is on the dial.
  5. the 3rd dwarve
    the 3rd dwarve Registered User
    Nov 3, 2000
    673
    23
    I would have to assume that if he’s referring to the case and buckle he started with castings and finished them to dimension. They could be billet but I don’t think one would want to start with a block of 18k rose gold and machine out those parts.
    Jeff
  6. hoo-boy
    hoo-boy Registered User
    Nov 13, 2008
    410
    retired
    1/2 mile past Resume Speed
    Well, the fun sure got kicked out of this one!:bang: hoo-boy
  7. Sterling
    Sterling Registered User
    Jun 10, 2009
    101
    jeweler, carburetor builder
    NY
    #7 Sterling, Oct 11, 2009
    Gold can cast detail surprisingly well. For the case & chassis, best would be to machine a block of wax. Shrink rate for usual 18K alloys is less than 2.5%; still enough to have to take into consideration when machining the wax. Then machining is really just to true up the work, with much less waste.
    Gold is "sticky" for machining and it readily binds with steel, so cutting tools need to be adequately lubricated. I use bee's wax for blades and lathe work.
    With gold and silver, there is a huge difference in the temper extremes. Annealed gold & silver is so soft that it's nearly useless for durability and for machining. So my GUESS is that the maker had the case cast and then heat treated by the caster. I know from experience that the difference between machining cast annealed gold and work hardened gold is like night & day.
  8. the 3rd dwarve
    Nov 3, 2000
    673
    23
    I have machined parts from both 14k and 18k soft yellow gold in the past. Some parts were cast and a few simple parts from solid bar stock. However, I was fortunate enough to have diamond tooling. When speeds and feeds are correct the diamond tooling cuts clean and leaves a finish that requires little additional polishing. They would disassemble the lathe for a good cleaning once a year and send the wooden work top out to be burnt.
    There really isn't enough detail in the description on the Taig site for us to know what the guy actually did.
    Jeff
  9. bchaps
    bchaps Registered User
    Dec 16, 2001
    1,130
    14
    Mountain Top, PA
    Regardless what may have been turned or cast, I am awestruck when I see this level of work by any individual.
  10. Dushan Grujich
    Dushan Grujich Registered User
    Jun 20, 2003
    621
    55
    Watchmaker
    Bondi
    Good Day to all,
    I too have turned gold and silver in my lathe. Two examples are shown on the images below. The first one is an IWC in a new 18ct. yellow gold case designed by an artist friend.
    My friend had cast a large ring of gold, which I used to turn the case from. Turning it was a major pain but it was well worth the effort. The final product was case of 2-1/2 oz of gold, without the movement. Case was additionally decorated with few diamonds just for a kick.
    http://i017.radikal.ru/0910/f5/d870cecca480t.jpg
    Unfortunately, this watch got stolen several years ago. I did that one over ten years ago. Since that time I have done other cases as well and have learned what one should not and what one could do with precious metals.
    The second one was a chrono, not a bit less of problem.
    http://i003.radikal.ru/0910/c5/ebb76e959a1at.jpg 148.jpg 149.jpg
    As with all other things in life it is live and learn.
    Cheers
    Dushan
  11. Mike Phelan
    Mike Phelan Registered User
    Dec 17, 2003
    9,836
    15
    West Yorkshire, England
    It is a beautiful job, but I'm sure it's just the case that has been made. The movement looks like a commercial one, and there's no way you could do things like cutting wheels of that size on a Taig.
    I'm no way decrying the work, though.
    Curiously, it was done in UK; on the forum here, I see talk of "making a clock" whereas the threads are really "making a clock case" as we in UK would call it.
  12. davestanda
    davestanda Registered User
    May 23, 2011
    667
    i think the person did make the movement..the movement to me looks in no way like something mass produced...the movement doesn't look like anything i had ever see...the movement i think was made.. the taig, i don't have one ..along with a sherline can make watch parts...from what i i have been reading both machines seem capable of making alot..like jerry says its the techinque and the way you do which is different...also i think if the person was able to make the movement i would think he would be capable of signing the movement... on other sites that talk about both lathes (the sherline and the tiag) if they show how someon made just the case they say how it is just the case that has been made..
  13. R.G.B.
    R.G.B. Registered User
    Feb 27, 2009
    665
    Photographer
    Vancouver B.C.
    The watch is nice but I'm thinking of the top project. It looks like you could thread the prop side of the engine to fit an 8mm headstock and extend the shaft through. You could turn between centers powered from the head stock. :)
