Name These Tools!
Discussion in 'Horological Tools' started by Laurie Kimble, Nov 8, 2018.
  1. Laurie Kimble
    Laurie Kimble Registered User
    Jan 30, 2011
    35
    I recently acquired a box of tools that I cannot identify. I would appreciate any help you could give me. Thanks for sharing your knowledge!
    105_8392.JPG 105_8393.JPG 105_8397.JPG 105_8395.JPG 105_8398.JPG 105_8394.JPG
  2. Dave Coatsworth
    Dave Coatsworth Forums Administrator
    NAWCC Business Donor Sponsor
    Feb 11, 2005
    5,463
    504
    Camarillo, CA
    Photo #4 is a counterbore/countersink set (first time I have seen a combined set)
    Photo #6 is a balance truing caliper
  3. Laurie Kimble
    Jan 30, 2011
    35
    That was fast! Thanks Dave! What is the primary purpose of the countersink set?
    I am not familiar with that style of balance truing caliper.
  4. wefalck
    wefalck Registered User
    Mar 29, 2011
    418
    12
    Paris
    Photo no. 3 shows a vice/anvil combination for stretching wheels. The tool would be held in the bench-vice.
    Do you have a picture that shows the tool in no. 1/2 from the front ? In any case it seems to intended to be held in the bench-vice too.
    The countersinks are used to fashion the countersunk holes for countersunk screw-heads. The little wheels have sharp edges that act like scrapers. The other insert tools are used to make cylindrical countersinks or, if the brass guidance-pins are removed, can be used to shorten screw-heads from underneath, as you would do with rose-cutters in the lathe.
  5. Laurie Kimble
    Jan 30, 2011
    35
    Wefalck,
    Thanks for your clear explanation of the countersinks and cutters set.
    Not familiar with 'stretching wheels.' I have used flat jaw pliers to elongate short teeth on clock escape wheels but not sure if that is what you mean.
    I have attached a picture of the front of the tool in the first 2 pictures.
  6. wefalck
    Mar 29, 2011
    418
    12
    Paris
    Yes, making teeth longer is what I meant. Your tool is a simple version of a variety of gadgets that were/are on the market for the pupose. I gather it is one step up in positive tool control from using pliers. There other versions, where the stamping tool is guided like in an upright drilling tool.
    As to the other tool: it looks a bit familiar, but flicking through my 110 year old tool catalogue I didn't see anything like it. It is certainly pre-1880 or so, judging by the style of the knurled nuts. I first thought it might part of a topping tool, but the vane for fixing it in a vice doesn't seem to go with this. I wonder, whether it might be a machine to be used with the so-called Ingold Fraises for cutting wheels ?
    Ingold Fraise. From the estate of noted watchmaker Dennis Harmon | eBay
    INGOLD FRAISE
    The straight items on picture no. 5 could be spare centres. Would they fit ?
  7. Neilywatch
    Neilywatch Registered User
    Oct 13, 2011
    15
    Hi - Picture #5 are jewelers tools - these are used to make graining and beading on rings. Hope this helps! Neil
  8. wefalck
    Mar 29, 2011
    418
    12
    Paris
    Oh, yes, the ones on the left are 'millegrain wheels', if they have little embossed wheels at the end.
  9. Laurie Kimble
    Jan 30, 2011
    35
    Thank you Neil and wefalck! So Picture #5 is not horological tools but jeweler's tools. Yes, the ones on the left do have little wheels at the end.
    I looked up the Ingold Fraise. Wow! $2,500!! That is one expensive tool. I don't think it matches what I have though I sure wish I did have one!
    A friend just found something in Crom's book that might be similar to pictures 1 & 2. Could it be a tool for dressing the back of the cylinder escape tooth to the correct angle? The one in the book is dated about 1820.
  10. wefalck
    Mar 29, 2011
    418
    12
    Paris
    It is actually the Ingold-milling cutters that are so expensive, because they are difficult to make and not made anymore to the best of my knowledge.
