Mystery device
ALR guy
Jun 8, 2021
55
11
80
Our local historical society was recently gifted a number of old clocks in various states of disrepair. We have a small team of clock repair people who are tackling the restoration process and nobody can identify one item. Unfortunately the original owner of this collection is now deceased so information about particular curiosities is unavailable.
Does anyone know what this pictured item might be?
Thanks in advance,
David
JTD
Sep 27, 2005
12,167
2,123
My first thought is that it might be a vertical spit jack missing its clockwork and spit rods. But that's just a guess - others may know more or better.
JTD
TQ60
Sep 15, 2016
472
77
Madera CA
It appears to once had additional material on the front frame.
There is a substantial gear ratio with that many gears, try different angle photos with Google image search.
Roy Gardner
Ticker Stopper
Jun 14, 2016
98
68
Cameron Park, California
Part of a bomb fuse? In major wars, clock & watch companies were put to work making them. Might be too much reduction.
Or perhaps part of a rev counter for an early steam engine? Might be too little reduction.
Early hand-cranked vibrator?
19,626
4,672
Both ends cylindrical, with a rubber seal at the top? It likely slid into a tube, or a machined cavity in something?? Willie X
JTD
Sep 27, 2005
12,167
2,123
Yes, I hadn't recognised that as being rubber but now I look closer, I think it is.
Guess my idea of a vertical spit jack is out. But those shafts obviously were made to turn something.
JTD
Cheezhead
Dec 30, 2010
289
53
Wisconsin
Estimated from what I can barely see it appears that the pinion below the first large gear has 6 teeth. The large gear it drives has 60 teeth resulting in a 1:10 ratio. The remaining two pinions and gears following above appear to have identical ratios making this mechanism unrelated to clockwork and more like part of a device that deals in multiples of 10 such as a watthour meter or an auto odometer.
It was not mentioned but a worm drive to the first gear at the bottom is possible.
If the OP would verify the large gear and associated pinion tooth counts, that could help to unravel the mystery.
19,626
4,672
If the assembly ran in oil, "O" ring down, it could act as a some type of speed controler??
19,626
4,672
I think Cheez is on the right track but that's some heavy duty construction for a counter!
Cheezhead
Dec 30, 2010
289
53
Wisconsin
Another feature is that the mechanism appears to be removable and replaceable due to the round top with the sealing ring being larger than the rest of it. It may have been intended to be used where ingress of water, oil, dust or even an air pressure difference would not be tolerable. Questions to ponder: What was done with the three shaft extensions? I don't see flats on the extensions so was there a resettable readout with hands like a clock?
zedric
Aug 8, 2012
2,308
648
Maybe the drive for a fuel or water meter? Something like an old petrol pump?
Richard.W
May 4, 2021
496
226
73
NE Georgia
Note the ratios seem to be the same for the 3 arbors to which indicator needles can be fitted. Back in the days of my youth, analog natural gas meters had a similar row of dials, such as the one pictured below. The missing part could be a small turbine that drives the counting wheels.
Latest posts
183,998
1,607,164
55,993
Boyeraiden
3,195
Top Bottom
