Mystery brass tool - "jewel setting tool"
Discussion in 'Horological Tools' started by rstl99, Apr 12, 2017.
  1. rstl99
    rstl99 Registered User
    Oct 31, 2015
    274
    Retired and free, with dog
    Ontario, Canada
    Also in the box of watch tools and supplies I acquired yesterday was this interesting little brass tool. Spring loaded little finger that can be raised or lowered onto a flat brass piece with a gap down the center.
    There was a faded folded schematic of the tool in the box, which refers to it as a "jewel setting tool". There was also a shaped flat brass piece of similar look and vintage which could go as part of the kit.
    Anyone familiar with this tool and how it is used? Thanks.
  2. Dave Coatsworth
    Dave Coatsworth Super Moderator
    Donor NAWCC Member
    Feb 11, 2005
    3,993
    Camarillo, CA
    This is a pallet stone warmer in a simplified Culman style. The spring loaded arm pins down the pallet fork. Heat is applied to the 'ears' to melt the shellac holding the jewels. The jewels can then be moved in or out to adjust the depth, or a missing jewel can be set in place.
  3. rstl99
    Oct 31, 2015
    274
    Ontario, Canada
    Wonderful, thank you Dave!
    I assume the other flat brass piece is unrelated to the actual warmer tool?
  4. Dave Coatsworth
    Donor NAWCC Member
    Feb 11, 2005
    3,993
    Camarillo, CA
    Unrelated. Not sure what that piece is for.
  5. rstl99
    Oct 31, 2015
    274
    Ontario, Canada
    Thank you again, all the best Dave.
Similar Threads - Mystery brass tool Forum Date
Drill bits modified for brass ? Horological Tools Apr 7, 2017
Mystery tool Horological Tools Dec 3, 2016
Another mystery tool Horological Tools Oct 13, 2016
Mystery movement holder Horological Tools Apr 24, 2016
Mystery tool! Watchmaking? Horological Tools Feb 23, 2016
