davidpaul
I will clean and oil the works, do some minor refinishing of the Walnut case and polish and lacquer the brass.
It is an Ansonia, "Made in Japan" short reach, school house, model.
it is missing one of the "buttons" on the front of the clock but that's no problem. After all, it was only meant for decoration.
My research shows that these clocks were imported, starting around 1914, to about 19 countries including, Russia, China, Australia and many more.
Do any of you members here know of something additional that I should be aware of before starting my work?
The enameling is almost perfect on the dial pan with only a small amount of checking but virtually no loss of detail. I will probably spray it with a satin finish poly to keep it that way.
The lower door has "A-Week" stenciled on the glass. I wonder what this means and if it is original?
Thanks very much for your fantastic knowledge of these old clocks and your acceptance of me as a new member,
David <><
