Help MY FRENCH MANTEL CLOCK RUNS ABSOLUTELY FINE WITHOUT A PENDULUM, BUT STOPS WITHIN COUPLE OF MINUTES
Discussion in 'Clock Repair' started by Siddharth, Mar 26, 2020 at 6:39 AM.
  1. Siddharth
    Siddharth Registered User
    Jul 3, 2019
    Dear All,
    I am faced with a very common problem. iahve a lovely French mantel clock which used to run fine until recently. when I run the clock without the pendulum it runs absolutely fine without any problems, as soon as I attach the pendulum the clocks stops running with few minutes. just as an exercise I did remove the weight from the pendulum and with only the rod was put back onto the clock. to my surprise the clock runs just fine without the weight. this s not the original weight of the clock, but used to run just fine. please do let me know if there is anyway of solving the problem.
    thank you very much in advance
  2. Ed O'Brien
    Ed O'Brien Registered User
    Nov 30, 2009
    563
    13
    Retired, and now full-time clock repairs.
    Winter Park, FL
    Is it in beat? Has it been cleaned and lubricated? Is it level front to back? Is suspension spring broken?
  3. Siddharth
    Jul 3, 2019
    Dear Ed
    Thank you for your response. yes it is in beat without the pendulum, I did get it out of the case and check the levels, the levels are all fine. the spring is not broken, it hasn't been cleaned for a while now.
  4. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,727
    270
    watchmaker
    Sounds like it is time to service it again.
  5. shutterbug
    41,701
    904
    Most clocks will run without the pendulum in place even if they are badly worn and won't run with the pendulum. Your symptoms are common to a clock that is having power problems. Especially is that true if it was running fine, and started stopping occasionally .... then finally stopped altogether. It is a problem that will require disassembling the movement, cleaning it, adding bushings to compensate for wear, and putting it back together. If you want to tackle it yourself, we can help. Otherwise, you will likely be looking for a local repairman who can do the work for you.
  6. R. Croswell
    R. Croswell Registered User
    9,676
    657
    You cannot set the beat with the clock running without the pendulum being attached. Round French clocks are typically mounted in the case using two straps that clamp the movement between the front and back of the case. Sometimes the movement will slip during winding if the straps are not tight enough, causing it to be out of beat. I don't understand what you mean that the levels are all correct. The clock can be level but still be out of beat. Try raising one side of the case a little and then the other side and see if it ticks more evenly when slightly tilted. If so, it is out of beat. If it is in beat and won't run then I agree with others, it is time for it to be disassembled, cleaned, and inspected.
    NEW65 and roughbarked like this.
  7. new2clocks
    new2clocks Registered User
    NAWCC Member Sponsor
    Apr 25, 2005
    1,984
    194
    Pennsylvania
    Siddharth,
    The following thread, regarding French strap movements, may be of assistance:
    French Bracket Clock
    Perhaps some pictures of the clock and the movement would be helpful.
    Regards.
    roughbarked likes this.
  8. Siddharth
    Jul 3, 2019
    Dear Ed,
    I was able to resolve the problem by removing and readjusting ESCAPEMENT.
    thank you so much for all the help
    PatH likes this.
  9. NEW65
    NEW65 Registered User
    Nov 17, 2010
    1,058
    26
    Deals in modern reproduction floor clocks.
    United Kingdom
    So, was the verge set too low to the escape wheel?
    (bottoming out) Or, maybe just a beat issue?
  10. Siddharth
    Jul 3, 2019
    I'm guessing more like a beat issue
    Thank you
