My first Sonora Chime Seth Thomas
Discussion in 'Your Newest Clock Acquisition' started by aesellitto, May 9, 2015.
  1. aesellitto
    aesellitto Registered User
    Jun 14, 2012
    91
    Finally the day has arrived, my first Sonora chime clock by Seth Thomas! I bought this today at an auction after a bidding war with another gentleman. The hammer dropped at 85 dollars!! I haven't been this excited in a long time. It will certainly find a place of honor in my collection. It is running and striking also. Just needs a bit of love and attention in clean up and a good oiling. The only thing wrong with it is the Westminster tune is out of sync. I think I found a thread here that will help me remedy this. If not, I will reach out for help in a post in the repair section. That is one clock removed from my bucket list! Woo Hoo!!
  2. Brian Smith
    Brian Smith Registered User
    NAWCC Member Donor Sponsor
    Oct 16, 2009
    511
    Building Official
    Manassas, VA
    At 85 clams you got a sweet deal. Congratulations!
  3. Jim_Miller
    Jim_Miller Registered User
    Mar 6, 2001
    672
    Jackson, Michigan
    nice clock and at a great price. does it strike on bells or rods?
  4. aesellitto
    Jun 14, 2012
    91
    It strikes on 5 bells. I drove an hour and a half just for that clock. And the auctioneer was so nice, per my request he had it up on the auction block within an hour. It runs awesome and sounds great other than being out of sequence. Seems like a fairly easy fix. I am going to give the movements a good cleaning so I can set it straight at that time.
  5. charlie44gs
    charlie44gs Registered User
    Jan 14, 2009
    37
    Classic Clocks, Atlanta
    Atlanta
    Congratulation of the sonora. It appears to be like my five-bell model. If you mean that the chime is out of sequence then trip the set-off lever on the back of the movement to get it chiming correctly. I found if I wind mine 7 or so minutes before it chimes I will set off the chime. I wind mine right after it has chimed.
  6. Andy Dervan
    Andy Dervan Registered User
    Oct 23, 2002
    2,244
    Hello,
    Sonora chime clocks are wonderful. Look the movements very carefully; they will probably require bushings; be very careful handling the springs in the barrels particularly chime movement - extremely powerful and could inflict serious damage on hands and finger - use a strong spring winder!!!
    They are wonderful clocks, but are high maintenance ladies as so much is going on - our 9 bell ones need major servicing every 3 years.
    They can be more complicated to get and keep running.
    Andy Dervan
  7. buddyboston
    buddyboston Registered User
    May 14, 2017
    I just acquired this ST 5 bell, which was my great grandmothers's. It appears to be in good shape, but the key is missing. The movement is 90B. Can anyone provide guidance where I can find a replacement key? Thanks so much.
  8. THTanner
    THTanner Registered User
    NAWCC Member Donor
    Jul 3, 2016
    961
    Carson City, Nevada
    Read through this post - http://mb.nawcc.org/showthread.php?140898-Seth-Thomas-Sonora-keys&highlight=seth+thomas+sonora+key
    The key for the time and strike is supposed to be the same as for the chimes. In the above thread we discussed why, for some reason, that was not the case on my Sonora. But basically you are looking for a number 6 if all your winding arbors match and all have similar wear and have not been filed to be cleaned up.
  9. harold bain
    NAWCC Member Donor
    39,980
    Best way to get a key for your clock is to take it to a clock repairman to have one fitted to the size needed. Either that, or order a few from a supplier to be sure to have the right one.
    www.timesavers.com
  10. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    961
    Carson City, Nevada
    This is an excellent suggestion since it is a double ended key. One end winds the springs while the other turns the regulating arbor that is usually just under the hands. You need a key that fits both areas properly.
  11. MartinM
    MartinM Registered User
    Jun 24, 2011
    2,319
    10
    El Dorado, CA
    #11 MartinM, May 15, 2017
    Technically, you'll want a "6/0000" key.
    Seth Thomas reproduction keys are available many places.
    Look for one with a nice small tip on the "0000" end because of the very small hole in your dial.
  12. buddyboston
    May 14, 2017
    THTanner. Thank you for responding and your advise!
  13. buddyboston
    May 14, 2017
    Thank you. I really appreciate your guidance!
  14. buddyboston
    May 14, 2017
    Harold, Thank you for your help with this. I really want to get this clock up and running.
Similar Threads - Sonora Chime Seth Forum Date
Sonora Chime Your Newest Clock Acquisition Sep 26, 2016
4-Bell Sonora Chime Strike Question Your Newest Clock Acquisition Feb 20, 2015
Sonora Chime Unit, Never seen one before Your Newest Clock Acquisition Oct 12, 2014
Seth Thomas Sonora 5 Bell Chime Your Newest Clock Acquisition Nov 2, 2012
SethThomas Sonora Chime #101 wall clock Your Newest Clock Acquisition Oct 30, 2012
