Hi
I'm trying to learn, with the aid of a couple of books, some simple watch repairing.
After diligent research, my first victim is a very simple (not even seconds hand) pin-pallet movement, picked up very cheaply. My aim is simply to dismantle, clean and re-assemble it. If it worked afterwards, that would be a bonus!
Currently hindering any notions of it ever working again is the disappearance of the tiny taper pin that this movement uses to fix the balance spring to the cock, in lieu of a balance spring set screw that de Carle seems to think it should have.
This pin was last seen, before it dematerialised with an almost inaudible 'tink' noise, in the grip of my tweezers. I was in the process of finding out how hard it is to put a pin in a hole without any depth perception.
Now, how do I replace a taper pin that most closely resembles the splinters of brass I have to pull from my skin when I've been turning brass?
Commiseration/advice gratefully rec'd.
John
John
