Well, after many years I have finally added an E. Howard clock to my collection. The reason I am posting, aside from showing off the clock, is to try and garner comments about this movement and when this clock may have been produced. Having very little knowledge of E Howard or catalogs, I thought I would throw it on the forum.
The clock is a #89 with a #1 movement. Notice the winding arbor ratchet mounted to the outside of the movement rather than integrated into the arbor. This allows easy let-down of the weight but can trip a bit too easily dropping it so you have to be careful. The pallets have clear jewels mounted in them that I assume are saphires. The escape wheel arbors are mounted in ruby's although the rear one was removed some time back and replaced with metal. The front one still seems to work great although it has a few chips and cracks.
The pendulum and weight are also heavy. Although the clock will run on a 5.5 lb weight, the weight that came with it is 9 1/4 lbs. The bob is very heavy at 5 lbs worth of brass and an odd adjustment. The pulley is large and heavy as well and looks a bit like the astro pulleys.
I have no idea if any of these are original to the case or not. Some of the stampings on the movement parts match and some do not. The case has a 1 or "I", the lock is a 6 (or 9), the movement studs and mount have a 5 on them, while the escapement bridge has a 7 on it.
I just have not owned an E Howard clock and these features appear to be out of the norm of the ones I have seen. Perhaps a good discussion is in order to explain what these features mean and when the clock was made. Any guesses?
