Harold thanks for the response, do you have a schematic or a picture of where the washer goes, let me explain what I have done. If I put a flat washer over the arbor that protrudes through the plate but before the minute barrel, the clock continues to work fine but the minute had will turn the arbor until the hand drops to the 6:00 position. If I placed a spring washer (one that is slightly con vexed) where the arbor protrudes from the plate with the con vexed side away from the plate facing towards the hands, my minute hand will stay in place and follow as suppose to, but the clock will stop in 20-40 minutes. No problems if I just run the clock with the hour hand on. I think I have isolated the problem, just not sure how to correct. Thanks to all in advance for your suggestions. DAVE
