• Upcoming updates
My First 400 Day Clock Service
imk
Nov 11, 2022
I have been given a Kern & Sohne Bentima 400 Day clcok that look exactly like the one in the below link:
When I received it the main spring was almost fully wound but the clock didn't run, so I gave it the extra quarter turn and it ran for a few days then stopped.
I gave it another quarter turn and same again, so I have fully released the main spring and have given it a couple of turns and it seems to be running ok.
Hence, as it has stood for years in a loft I think the main spring has glued up and the clock basically needs a good service.
So question what oil's to use on this type of clock please?
Many thanks in advance IMK
KurtinSA
Nov 24, 2014
5,746
586
San Antonio, TX
Welcome, IMK! Lots of thoughts on this, but generally you should try to find a synthetic oil and one of low viscosity. A good place to start is say Mobil1 0W5 or the like. Not sure what you have over there. The spring will need a good clean to get all of the old oil and varnish off of it. Then oil just a bit...you don't want to soak it in oil as that creates its own set of problems. You will need a main spring winding tool in order to easily and safely get the spring in/out of the barrel.
Let us know what you find when you get the spring out!
Kurt
imk
Nov 11, 2022
Hello Kurt and many thanks for the reply.
I had a look at couple of videos re removing main spring and spring winding jig etc.
It doesn't look rocket science and I think i can use the key harbor in my lathe operated by hand.
Then fashion something to hold other end of spring while winding it.
As far as Mobil 1 0W5 is concerned I couldn't find any reference to it on the web either in UK or USA.
Hence I'll have a hunt for an alternative low viscosity synthetic oils
Many thanks imk
Dells
Oct 18, 2019
1,039
320
In the cotswolds UK
Many thanks imk
Hi imk
I am in UK and I use Mobil 1 0W5 only because it’s what I use in my car so what ever you use in your car and as long as it’s fully synthetic and low viscosity it will be fine.
Dell
178,997
1,570,067
54,045
QMAC
909
3,088
Swiss Fake by Kent
