newest ( to me ) watch, I just picked up a 1904-05 18S Bunn Special... 21 Jewels in GJS, adjusted 6 positions, plus temp & Iso serial 1788377... probably a gold meld down orphan, but someone stuck it in a nice heavy Duber sterling hinged crystal open face case... ( I like the hinged front with the lever set, works better for me, for occasional use, than the screw fronts ) seems to run great, hands are probably the weakest point on the watch, the minute hand has a little corrosion, face has one faint hair line on the triple sunk dial, the back of case had engraving, thats pretty worn, but I like it alot... will have to get it in for a clean & lube... ( no scratching on the case, so no idea when it was last serviced, or if that would have been on this movement )
this has been a bad couple years on the scrapping of nice watch cases... I'd love to have "one" gold watch case, but there is just no way I can afford a nice movement in a gold case, at this point in my life... maybe someday, if they don't all get scrapped
anyone able to tell me anything about this one ?? maybe what type of case it would have been in originally??
