My Ansonia "La Duchesse"... Rare bird or incorrect dial?
Discussion in 'Your Newest Clock Acquisition' started by bikerclockguy, Aug 7, 2017.
  1. bikerclockguy
    bikerclockguy Registered User
    Jul 22, 2017
    165
    View attachment 352742 View attachment 352743
    I picked this up at a yard sale(non-running)for $20 a week ago, and I now have it running, so I decided to try to get an idea what I had and what it might be worth. From all the evidence I've seen, I believe this is a "La Duchesse" model. I've seen them with the same detail right down to the pinstripe design, with one exception: I have yet to see one with a gold dial and Arabic numerals. All of them I've seen have had white dials with Roman numerals. I wouldn't be the least bit surprised if someone had swapped dials, except for one thing. The guy I bought it from was about 80, and he told me it was his grandmother's clock and had been in their family since it was new. I can't see adding a windy tale like that to a $20 clock I was going to buy anyway, so that got me wondering what I have here. The movement looks original to the clock and has "Patented June 18, 1882" on the left side of the back plate, and a weak number 5 stamped opposite this on the right. Any ansonia experts out there that can shed some light on this? -Thanks!
  2. JTD
    JTD Registered User
    Sep 27, 2005
    3,947
    19
    I am not an expert in American clocks but I believe these clocks were sold with options - you could get them with various styles of dial. Those who are knowledgeable about these clocks will be able to confirm or not - I may have remembered wrong.
    As you probably know, we are not allowed to discuss values on this site but in my opinion it's not a particularly valuable clock.
    Those with access to the Ansonia books may be able to give more information.
    I expect you are going to replace the bit of wire holding the suspension spring?
    JTD
  3. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,866
    watchmaker
    Western NSW, Australia
    Re: My Ansonia "La Duchesse"... Rare bird or incorrect dial?
    Back in the day it probably didn't cost more than $25.
    - - - Updated - - -
  4. Steven Thornberry
    Jan 15, 2004
    17,815
    20
    It does appear to be the La Duchesse. It is shown in Tran Duy Ly's book on Ansonia clocks (arlingtonbooks.com) from the 1880 catalogue with a plain white dial, no visible escapement, and with the addition of a clock topper, which I suspect was an option. It is also shown from the 1886 catalogue with a white dial and visible escapement. There is no mention in either case of dial options, but that does not mean they were not available. However, Tran's book shows an 1894 catalogue illustration of the Cardiff with what appears to be the same dial as on yours. AS JTD said, dial options were frequently available, and the catalogue illustration and description for any particular year would not necessarily preclude differences in other years, as is, in fact, shown by the two catalogue illustrations of the La Duchessse. I will assume that the La Duchesse might have been offered some years after 1886, and a different dial would be possible. Unless there are clear indications that the dial is a replacement, I would accept it as original.
    Prices are not shown for the La Duchesse in 1880 and 1886, but I suspect that $25.00 might be a bit high. The Vienna shown from the 1904 catalogue is listed with three dial options. The prices ranged from $10.00 to $12.25, depending on the option.
  5. George Nelson
    George Nelson Registered User
    Oct 5, 2007
    884
    Tennessee
    Hi, All,
    Just for what it's worth, according to my inflation calculator, $25.00 in 1886 is equivalent to $641.03 in today's money. Not a cheap clock in its day!
    Best to all,
    George
  6. JTD
    JTD Registered User
    Sep 27, 2005
    3,947
    19
    As Steven surmised in his post, going by the catalog prices, and although it is not specifically priced, it likely cost a good deal less than $25.
    JTD
  7. bikerclockguy
    Jul 22, 2017
    165
    JTD, I'm glad you brought that up. I think this is probably cosmetic enough to be acceptable material here. There was what appeared to be bent brass wire holding the spring rod, and I assume that's original equipment. In the process of trying to straighten it enough to remove, it snapped off and was too short to reuse. Is that something that's commonly available? I was in a pinch, so I used a staple, but I'd rather have something that looks more original.
  8. JTD
    JTD Registered User
    Sep 27, 2005
    3,947
    19
    That bit of wire certainly wasn't original!
    You need a tapered pin that every clock maker/repairer will have hundreds of in different sizes. You can of course buy them from all the regular clock suppliers (Timesavers, Merritts etc.) but you can't buy just one, they come in packets of at least 50 and in many different sizes. That it why I suggest you ask a clock repairer who will be able to give you one and would charge very little, perhaps nothing.
    But a staple will do for now............
    JTD
  9. roughbarked
    Dec 2, 2016
    1,866
    watchmaker
    Yes. All the catalogues I haveseen put 1910 prices at what you say but some of the more expensive clocks were upto $25.
    - - - Updated - - -
    No clock was ever cheap really. Mass production made them more available to the masses, is all.
Similar Threads - Ansonia Duchesse Rare Forum Date
Ansonia Santa Fe case is it a reproduction? Your Newest Clock Acquisition Sunday at 1:37 PM
Dating Ansonia 8-day time only clock Your Newest Clock Acquisition Oct 11, 2017
Ansonia "Iris" Electrolier Your Newest Clock Acquisition Oct 8, 2017
Info request on Ansonia Idaho model Your Newest Clock Acquisition Sep 19, 2017
Rare Advertising NH Store Regulator Your Newest Clock Acquisition Jul 20, 2017
